GODspeed opened this issue on Mar 19, 2005 ยท 11 posts
GODspeed posted Sat, 19 March 2005 at 8:45 AM
dlfurman posted Sat, 19 March 2005 at 8:52 AM
Smooth Polygons: OFF?
space
DCArt posted Sat, 19 March 2005 at 8:53 AM
GODspeed posted Sat, 19 March 2005 at 8:56 AM
Smooth is off. Render is Production quality
Dave8 posted Sat, 19 March 2005 at 9:24 AM
u need to take smooth of for each prop or figure as the option in the render settings does not seem to work
Fugazi1968 posted Sat, 19 March 2005 at 9:42 AM
curse that polygon smothing
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
Ayelmar posted Sat, 19 March 2005 at 10:46 AM
(See attached...)
-Timberwolf- posted Sat, 19 March 2005 at 11:00 AM
Set Smooth Poligons off in render settings .Make sure to use the Poser Service Release 3 or 4 because the render- engine ignore this setting in earlier Releases.
caulbox posted Sat, 19 March 2005 at 11:28 AM
Are you selecting the option in the P4 renders to "Ignore Shader Trees"? If so... then is it a possibility that there is an ambient colour other than black being used. Even with an ambient value of zero, the Poser 4 render engine will render in accordance with the ambient colour if you have selected the option to Ignore Shader Trees.
Message edited on: 03/19/2005 11:31
Olivier posted Sat, 19 March 2005 at 2:04 PM
The problem does not come from the firefly, nor Poser but from the geometry of your cell. It is not "smooth" friendly. Select these objects go to their properties and uncheck the "smooth" option. You could also uncheck the "smooth"option in your render settings but I don't recommend you to do so: you'll loose the smart smooth shape of your character... OK? :)
Ayelmar posted Sat, 19 March 2005 at 7:21 PM
