Subject: For those saying AO in P6 creates artifacts...
Nalif opened this issue on Mar 22, 2005 ยท 7 posts
Nalif posted Tue, 22 March 2005 at 9:40 AM
It just takes some tweaking. I set the AO sampling size from 3 to 6 and it looks much better. This scene has one light set to IBL and AO turned on. I'm using a picture I found of the sky via google ( didn't like the included IBL AO set ) and I found that if you take the same picture and lighten it via a color_math node, and then plug the result into the diffuse node of the light that it has much better results. The character is Jessie with the WinterQueen hair. I set up a basic skin shader with the new fastscatter node.
Message edited on: 03/22/2005 09:44
shedofjoy posted Tue, 22 March 2005 at 9:53 AM
Love the render, can't wait till my P6 arrives in the post. I love the shadows in this...
Getting old and still making "art" without soiling myself, now that's success.
stonemason posted Tue, 22 March 2005 at 9:59 AM
yes,nice shadows ..how long was the render?(& how big)
Cg Society Portfolio
Nalif posted Tue, 22 March 2005 at 10:04 AM
The image is at the size it was rendered at. As for the render time, I'm not sure as I wasn't timing it. Another thing to consider is the back drop - it's a little heavy on the polygons right now because I haven't optimized it yet. I'd say it took around 10-15 minutes. I have pixel samples set to 9, raytrace turned on and max texture size turned to 3000. Raytrace bounces are set to 3.
stewer posted Tue, 22 March 2005 at 10:56 AM
You should get away with less pixel samples and save some render time - 3 is a good default when you're not using strand based hair or depth of field.
lululee posted Tue, 22 March 2005 at 3:45 PM
Nalif, Where is the fastscatter node? She has very nice skin. Nice render. cheerio lululee
Nalif posted Tue, 22 March 2005 at 7:59 PM
The fastscatter node is under new node > lighting > special .
