steama opened this issue on Mar 23, 2005 ยท 28 posts
steama posted Wed, 23 March 2005 at 2:17 PM
I noticed that Poser 6 is now shipping. Does anyone in the community know if Poser 6 plays nice with Carrara's New Transposer 2? I know I may be a bit early with this question but I was wondering before I purchase Poser 6. Thanks for any info provided...
mdesmarais posted Wed, 23 March 2005 at 2:38 PM
http://groups.yahoo.com/group/Carrara/message/56774
steama posted Wed, 23 March 2005 at 8:06 PM
good info, thanks
souleat posted Tue, 29 March 2005 at 10:11 AM
and for us? work or not ????
AndyCLon posted Thu, 31 March 2005 at 12:33 AM
Just got an email back from Eovia Technical support and although they were not willing to give a definate "thumbs up" they mentioned that some people had got this to work. The important thing appears to be to install Transposer after installing Poser.
InfoCentral posted Thu, 31 March 2005 at 9:56 PM
Poser 6 ships with Shade 7 LE which has PoserFusion build into it. So you can render Poser scenes within Shade. The word is that even Shade 7 doesn't handle all of Poser 6's new features. So I would be very surprised if Transposer is able too.
steama posted Fri, 01 April 2005 at 1:39 PM
What does one do if they never had Poser 5?
kilal posted Fri, 01 April 2005 at 1:58 PM
I hope Eovia is gone a do something...
InfoCentral posted Fri, 01 April 2005 at 5:16 PM
What happened to the left side of the face?
steama posted Sat, 02 April 2005 at 1:22 AM
kilal, GREAT NEWS! How did you do it? 1) Did you need to select an older Poser exe like Poser 4 or 5? 2) Did you install Transposer 2 after Poser 6? 3) Was any other version of Poser installed? last one 4) Did you need to install the Transposer 2 plugin twice? Good Job!, Appreciate any additional details. Steama
kilal posted Sat, 02 April 2005 at 10:36 AM
kilal posted Sat, 02 April 2005 at 11:08 AM
Hi! It's me again! I finally understand what happened with transposer2. I can't import any file if i don't select poser 5.exe when i import
a figure for the first time.If a figure have ever been imported by poser5 exe, the next times i can select poser6exe and it works well.At this time i don't know if animations are imported correctly.On my first try the body animation was ok but not the face morphs.I received poser6 yesterday in the morning .just beginning the tests .
Have nice day ! kilal
steama posted Sat, 02 April 2005 at 11:59 AM
Thanks Kilal
You have helped out alot.
Steama PS: I will send any new information to Eovia
Message edited on: 04/02/2005 12:02
InfoCentral posted Sat, 02 April 2005 at 10:54 PM
I see the close-up picture has been deleted. I guess that answers the question of what happened to the left side of the face. All and all looking at the shadows on the skin and face I can say it doesn't handle them too well. This was really evident in the close-up picture that was deleted.
kilal posted Sun, 03 April 2005 at 9:16 AM
kilal posted Sun, 03 April 2005 at 11:00 AM
In conclusion i think that Transposer2 doesn't work properly
with Poser6.I can import characters ,body animation but not face morphs.I hope Eovia will update Transposer2 soon.
PS.If someone have new informations about that or if you think i'm wrong let me know...
Regards kilal :-)
steama posted Sun, 03 April 2005 at 11:23 AM
Kilal, On face morphs importing into Carrara 4...it won't happen yet (not until Curious Labs can produce a Poser 6 SDK). I have read a post that facial expressions do not even work in Shade yet. Steama
InfoCentral posted Sun, 03 April 2005 at 1:03 PM
Kilal, The new close-up, is that a FireFly render or one done in Carrara? I noticed that the top of the head looks like the curve is done with short straight lines. Same thing with the right ear.
InfoCentral posted Sun, 03 April 2005 at 1:09 PM
Yes, the new close-up does look better thought. But if you look at the girl in the green top you can see the same shadow problems on her forehead. And what is going on with the right wing of the Winter Queen.
kilal posted Mon, 04 April 2005 at 9:33 AM
The new closeup is done in Carrara4Pro .Any way transposer2 doesn't work properly with poser6 in fact i used
poser5 exe to import.You can understand that poser5 exe doesn't have a full compatibility with poser6 characters,problably there some informations missing or misunderstood by poser5 exe.The best thing to do is to wait for transposer2 update:-)
InfoCentral posted Mon, 04 April 2005 at 9:54 AM
Sure. The Poser -> PoserFusion -> Shade isn't 100% yet either.
steama posted Mon, 04 April 2005 at 11:32 AM
I was told by someone at Eovia that Transposer 2 does not use the Poser.exe file that Transposer 2 wants you to select in order to import a Poser file. Transposer 2 uses its own Transposer 2 Poser Run Time to open the Poser file (I bet it is based on Poser 5 SDK). Transposer 2 simply wants you to select a Poser exe to verify Poser is there in order to bring in a Poser file. So I guess that means that the programming in Transposer 2 is based on Poser 5 SDK, therefore, it is not totally compatible with Poser 6 (doesn't even recognize it as a Poser.exe file). As stated in this thread even Shade is not 100% compatible either with Poser 6. Steama
kilal posted Mon, 04 April 2005 at 12:46 PM
You're right! At this time Eovia is waiting for Poser6 SDK.
ShawnDriscoll posted Mon, 04 April 2005 at 1:03 PM
So they can make a Transposer 3 for importing Poser 6 files in time for Poser 7. :)
steama posted Mon, 04 April 2005 at 1:11 PM
Jus' like before! LOL
InfoCentral posted Mon, 04 April 2005 at 6:17 PM
kilal, why do you keep posting your pictures and then deleting them?
kilal posted Mon, 04 April 2005 at 7:06 PM
I have deleted these posts because i was wrong:-( but if youn want i can report the pictures:-)
InfoCentral posted Mon, 04 April 2005 at 7:25 PM
You weren't wrong. You were just posting your results. That's all.
