Subject: Converting obj PC files to Mac files
creativeczar opened this issue on Jan 20, 2001 ยท 6 posts
creativeczar posted Sat, 20 January 2001 at 9:16 AM
I am trying to convert obj files (props) that came on the content CD with Poser 4. Mac Converter is not working. Nor does File Typer. Does anyone have a suggestion? Thanks for your help.
ravenfeeder posted Sat, 20 January 2001 at 9:26 AM
I don't know about the obj files on the CD, but I've had no problem converting the ones I've gotten in Renderosity free stuff to Mac format with Mac Converter. Not sure what the difference is. Have you tried using Mac Converter on any files you got on Renderosity? Might be a good check to see if it's working properly.
doozy posted Sat, 20 January 2001 at 10:32 AM
OK I tried it out. On the content CD I chose OBJ Props:Assorted objects:Bench.obj I copied it to my hard disk (this step may not be needed). No conversion was needed, Poser recognized the file for import Wavefront OBJ. But I didn't see anything in Poser. Looking at the coordinates in the file itslef, I see that it is (in poser units) about 100 feet underground and 80 feet to the side. Plus being 50 feet high itself... (In the picture, I moved it, so that you can compare it to a Poser figure). SO, when you import this, check to box "Percent of standard figure size" and enter a reasonable amount. Then at least you can see it to adjust the size.
MikeJ posted Sat, 20 January 2001 at 4:22 PM
That's one HUGE bench there, LOL! When you say, "I see that it is (in poser units) about 100 feet underground and 80 feet to the side. Plus being 50 feet high itself... ", how do you know that? is there a way to tell the size of things, relatively speaking? --MIke
creativeczar posted Sat, 20 January 2001 at 5:53 PM
Thank you all for your input. I was able to import the files with no trouble. I was confused - ugh --. Since I downloaded free props from Zygote and they showed up in my menu under props, I expected to find my props in the same area. My mistake.
doozy posted Mon, 22 January 2001 at 7:28 PM
how do you know that? is there a way to tell the size of things, relatively speaking? Well, I usually take 1 Poser unit to be 100 inches (or about 8 feet). For example, this bench (when you view it in a text editor) had y coordinates down to -14 or so, about 100 feet underground.
