Subject: P6 and removing the Content Room
Indoda opened this issue on Mar 25, 2005 ยท 17 posts
Indoda posted Fri, 25 March 2005 at 11:19 AM
Does the trick that was used for P5 work for P6? I tried it but must have missed something as it came back by itself!! Is it worth the hassle? TIA
The important thing is not to stop questioning.
- Albert Einstein
Indoda
Gareee posted Fri, 25 March 2005 at 11:33 AM
Yep, it works.. here's the link to poserpros, and Neitherworks excellent pdf on how to do it: http://poserpros.daz3d.com/forums/viewtopic.php?t=16569
Indoda posted Fri, 25 March 2005 at 11:42 AM
Thanks Gareee I knew there was a .pdf somewhere was trying to do it from memory. Memory is failing ;(
- Albert Einstein
Indoda
Gareee posted Fri, 25 March 2005 at 11:51 AM
I saved it in my documents, and also saved the link, in case I forgot it. (it was reposted somewhere recently)
No if I HAD the frickin thing so I could remove content paradise from it.. LOL!
Message edited on: 03/25/2005 11:51
RealDeal posted Fri, 25 March 2005 at 1:20 PM
can anyone give a synopsis? I don't feel like signing in to poserpros today.
Gareee posted Fri, 25 March 2005 at 1:29 PM
You don;t want a synopsis for screwing around removing the room. get Nietherwork's pdf from the link.
kaveman posted Fri, 25 March 2005 at 3:56 PM
Yes, it works but it doesn't give you that speed boost P5 needed while loading. So there's no performance advantage in doing it. YMMV.
Gareee posted Fri, 25 March 2005 at 4:02 PM
I imagine ther has to be some speed increase beacues you are not loading resources. Plus, when working, every bit of memory is worth retaining.
hein posted Sat, 26 March 2005 at 7:07 AM
Synopsis:
1: MAKE A BACKUP OF POSERSHELL.XML before you mess around
2: Open /...runtime/ui/posershell.xml in a texteditor , completely remove the 3 lines that contain "ContentRoom" , save
Gareee posted Sat, 26 March 2005 at 7:16 AM
except there are more then just 3 lines that say content room to be removed.
hein posted Sat, 26 March 2005 at 7:26 AM
A search in the XML only found 3 , removing those 3 lines was enough.
Gareee posted Sat, 26 March 2005 at 7:29 AM
did you read the faq at the link I provided? Check the last entry to delete.. it's about 5 lines..
hein posted Sat, 26 March 2005 at 7:48 AM
If I set my texteditor to wrap at #80 I get 5 lines too, the link points to a log-in screen, not going to register to yet another board. Since removing the 3 or 5 lines worked fine here, even without reading the faq, I thought I'd mention it.
Gareee posted Sat, 26 March 2005 at 8:11 AM
I'd just hate to see someone screw up thier poser install, because they were too lazy to read a complete walkthough. And of course now we've both wasted both time and bandwidth, reposting in essence exactly what the link I provided had in it. And I think it's already been reposted here at rendo about 20 or so times.
Message edited on: 03/26/2005 08:12
RealDeal posted Sat, 26 March 2005 at 10:35 PM
Ahh, but at least I did not have to sign in to poserpros! the thread was a success for me! * this post is not version specific
Gareee posted Sun, 27 March 2005 at 7:31 AM
Yeah, but you could have had the information 2 days ago, but was too lazy to go get it yourself.
