Subject: Help with my first Poser scene!
MoonFlower opened this issue on Mar 26, 2005 ยท 4 posts
MoonFlower posted Sat, 26 March 2005 at 7:03 AM
How can i scale my character with clothes, props and everything?
AntoniaTiger posted Sat, 26 March 2005 at 8:51 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1942965
Check this thread for one description of how one user does it, for the whole scene. If clothes, props, etc, are parented to the same figure, then just rescale that figure. I've a recollection of somebody saying you could use a dummy prop to scale and move a whole set of figures, setting the prop invisible for the render.
MoonFlower posted Sat, 26 March 2005 at 9:08 AM
Thanks alot. :)
lesbentley posted Sat, 26 March 2005 at 5:54 PM
One is to load a square prop, parent everything to the square. Then scale the square, everything else should scale with it. Last, from the squares Properties make it invisible. If you only need to save as a pz3 the above method is fine. Or you could download the MinFig cr2 from the Free Stuff, and parent everything to that. The advantage is that if you then resave MinFig to a figures pallet with a new name, all the figures and props parented to it will save with it, and you can load everything into your document all at once, at the right scale. Min fig its self is invisible, and at under 5 KB file size very small.
