Holli opened this issue on Jan 22, 2001 ยท 6 posts
Holli posted Mon, 22 January 2001 at 3:58 AM
Attached Link: a little problem with OBJ import
Hello, a little problem with OBJ import. I've created a suitcase in MAX. I made two files of it so it was much easier to paint in the UV-Maps. I import both files in Poser and aply the texture-maps on it. How do I make one file of it ? When I export as obj and reload it I have one object but only one texture-map is applied. What is here to do ?JeffH posted Mon, 22 January 2001 at 4:04 AM
Attached Link: http://www.uvmapper.com
Do you use UVmapper? You'll have to create two materials. The first material would use one map, the second material would use the other map. I'm assuming you're using Poser4? The victoria and Michael figures use this scheme as well.Holli posted Mon, 22 January 2001 at 4:18 AM
Yes, I'm using UVMapper and Poser 4 So I can create more than one bitmap out of an obj file ?
JeffH posted Mon, 22 January 2001 at 7:33 AM
Yes, you select the material that you don't want to show and use a hotkey to hide it. Then when you save the template you can choose not to include the hidden parts of the UVs on the image.
Holli posted Mon, 22 January 2001 at 8:02 AM
And in Poser I can apply different maps to different materials, right ? I'll try this out.
JeffH posted Mon, 22 January 2001 at 8:49 AM
Yes, with Poser4 in the materials dialog, make sure "texture changes apply to entire figure" is unchecked.
