Forum: Poser Technical
Subject: poser path problem?
mlofrano opened this issue on Jan 22, 2001 ยท 2 posts
mlofrano posted Mon, 22 January 2001 at 6:18 PM
Has anyone run into this problem? I am trying to "make movie" (not an avi but a sequence of images). I am using walk designer along with a path. If I leave the figure pointing straight forward and then render the movie(sequence) the sequence file gets created just fine, thank you. It creates the 30 seperate images of the figure progressing through its walk. If, however, I rotate the figure so that it is a 3/4 view, when I execure the render I get a series of images that are al the same, that is the whole sequence consists of an image of the figure in its intitial position over and over for the 30 frames--no movement. What am I doing wrong? Thanks everyone.
