bagoas opened this issue on Mar 30, 2005 ยท 5 posts
bagoas posted Wed, 30 March 2005 at 1:28 PM
I'm 'working my way' trough learning the P5 Materials room. I do have substantial previous experience with script-based modelling (PovRay) so I am going trough a mix of the feast of recognition and the fustration of not finding/seeing the obvious.
I'm stuck on one thing. I am probably overlooking: How can I get the 'intrinsic' textures, such as 'brick' or 'tile' have another orientation towards my object's u/v axis? I can shift the pattern in u and v direction, but I do not see how to rotate it.
So, in short, how can I fill a standard one sided square with a diagonal pattern of tiles without using image/transparency maps, or slaving into highschool math and work out a complex thing with sines and cosines and other math stuff, which would be overly complex and probably terribly slow to render?
Any help appreciated
Likos posted Wed, 30 March 2005 at 2:30 PM
I would like to know this also. I end up in photoshop for things like this but I've wondered if there was a quick and dirty way to do it.
semidieu posted Wed, 30 March 2005 at 3:33 PM
There is no easy way... or i don't know it. Some many thread ago, there was a complicated shaders to rotate an image map... I'm trying now to apply it to an other node...
semidieu posted Wed, 30 March 2005 at 3:43 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2135952
And yes... it works if the node you are using has the "U_Offset" and "V_Offset" (image_map, tile, brick and movie, but not the weave node). You can find the material template in this thread (link above). Go to post 8 for the screen shot (very impressive ;-) ) and to post 11 to download the P5 Material file.bagoas posted Wed, 30 March 2005 at 11:36 PM
Very impressive indeed. I will try it out and give it a prominent place in my 'tips and tricks' collection. I do not dare even to think about rotating 3-d textures..... Thank you semidieu and nruddock.
