T:-)M opened this issue on Mar 30, 2005 ยท 7 posts
T:-)M posted Wed, 30 March 2005 at 4:06 PM
I have some problems with Jessi ;-) in Poser 6.
There are edges (1) a bump (2) and a rips - belly part which is not normal.
What a pitty it's a realy nice Character....
Can you help me - what can I do?
Greetings
T:-)M
nerd posted Wed, 30 March 2005 at 4:15 PM Forum Moderator
1, Smooth Polygons in the render settings. 2, Use the high rez version, it's not just a texture, the mesh is twice as dense. Nerd3D
T:-)M posted Wed, 30 March 2005 at 4:17 PM
Hi Nerd3D, wow that was quick ;-) I'll try that ... Thanx.
Grace37 posted Wed, 30 March 2005 at 4:47 PM
the bump you circled looks like the collar bone being highlighted by the light
T:-)M posted Wed, 30 March 2005 at 5:16 PM
Hi Nerd3D, Hi Grace37, .... o.k. problem 1 solved ;-) I think problem 2 should be the collar bone - but it looks not natural....the same fr problem 3..... T:-)M
nerd posted Wed, 30 March 2005 at 6:28 PM Forum Moderator
There may be morphs to change the shape of the collar and rib cage. If they are not available now, one of the morph artista will likely create some. Nerd3D
Letterworks posted Wed, 30 March 2005 at 9:34 PM
For problems 2 and 3 I think it's more a matter of taste. Jessi seems to be a bit more "muscular" than the normal Poser base figure. Unfortunately, unless there are morphs to change the body type ( I don't have P6 yet), there isn't a lot you can do except make the morphs yourself or wait for the morph master to gear up. I'm sure it won't be long once the box versions of P6 begin arriving before a whole bunch of Jessi body morphs become available. mike
