AndyCLon opened this issue on Mar 30, 2005 ยท 7 posts
AndyCLon posted Wed, 30 March 2005 at 6:00 PM
Attached Link: Flea Circus - Flea on tightrope
I am modelling a unicycle on a tightrope and have been using Cognito to control the motion via a rack, rocker, gear and cam.However, I want to rope to dip at the same time as the movement of the cycle.
I tried using Akira Kurozuka's Potentializer but this did not seem to work. I could not perswade the 0 and 100% animation settings to take and I'm not actually sure it would produce quite the right effect.
So does anyone have any suggestions?
Thanks, Andy
http://www.fleacircus.co.uk
kelley posted Wed, 30 March 2005 at 9:17 PM
What about a very thin cylinder in the Spline Modeler with only three cross-sections? You could slide the center cross-section back and forth along the rope and pull it downwards to match wherever the unicycle is at any particular frame.
noviski posted Wed, 30 March 2005 at 9:19 PM
Well, in this case, first I create the rope with morphs, just like the animation as you need. Then I put the cycle using the motion path as the same animation of the rope. Sorry about my English, Andy. I dont know if I could express myself, but I rope, oops, hope you can catch the idea. ;-)
noviski posted Wed, 30 March 2005 at 10:12 PM
Message edited on: 03/30/2005 22:12
AndyCLon posted Thu, 31 March 2005 at 12:24 AM
Thanks for the feedback
kelley posted Thu, 31 March 2005 at 9:21 AM
I'm not familiar with Cognito, [nor have I used morphs, for that matter] but if you made the rope the 'parent' and the unicycle the 'child', it should follow the rope no matter where you pull it.
Nicholas86 posted Thu, 31 March 2005 at 8:27 PM
You could also use potentializer and have it track alongside the unicycle. Brian
