Subject: Getting to grips with P6
tbird10 opened this issue on Apr 01, 2005 ยท 2 posts
tbird10 posted Fri, 01 April 2005 at 10:30 AM
Starting to have a 'serious' play now, going to take a bit of time to 'relearn' some tricks This image is using the supplied content and poses. 1. Open GL preview 2. Default light set - oops lights outside the building 3. 2 diffues IBL lights with AO, not what I'm after 4. 1 IBL light with a sky image, one point light, swapped the strand based hair to transmap and slightly tweaked the textures, now I'm getting there. This is going to take a while :-)
kuroyume0161 posted Fri, 01 April 2005 at 3:05 PM
I found that one IBL with one or more point lights makes for more realistic lighting conditions. IBL alone seems to be very washy and, well, ambient. :) I think that is why Ambient Occlusion is really necessary (if set properly) to get better shading. I placed one point light near the IBL light and another opposing to get a good effect. Yes, this is going to take some time. If you read the tutorial PDF (Chapter 12), it makes it quite clear that render output is dependent upon lighting, render settings, and materials together. That makes for much experimenting.
 -- Bjarne Stroustrup
