Subject: Pooser 6 troubles, help please.
OReillyTX opened this issue on Apr 01, 2005 ยท 2 posts
OReillyTX posted Fri, 01 April 2005 at 11:24 AM
Ok I have many external runtimes ,for male ,female figures and environments etc. I created a D3 character and saved it. When I load that figrue again none of the morph data is there on the mesh.The dials appear to have the porper values ,but dont seem to work at all now.What is causing this? Any help greatly appriciated.
nerd posted Fri, 01 April 2005 at 1:51 PM Forum Moderator
Did you move the figure with an external file manager like windows explorer? The PMD files for the figure have gotten disconnected. Move the figure back to it's original location. Open in Poser and add it to the new library using Poser's UI. (the little (+) at the bottom of the library.
P6 is supposed to let you look for missing PMD files so there may be a bug there or it may have "found" the wrong one.
You could also edit the CR2 to make sure it points to the correct forder for the PMD. If you are familiar with editing CR2s it looks a lot like the OBJ refrence in the CR2 and there are two of them just like the OBJ line. Nerd3D
Message edited on: 04/01/2005 13:53
