poseadel opened this issue on Apr 01, 2005 ยท 7 posts
poseadel posted Fri, 01 April 2005 at 10:23 PM
poseadel posted Fri, 01 April 2005 at 10:24 PM
poseadel posted Fri, 01 April 2005 at 10:27 PM
nruddock posted Fri, 01 April 2005 at 10:41 PM
Gareee posted Sat, 02 April 2005 at 7:12 AM
And for P6, you should be able to set your opengl for quality without slowdown or issue.
steve_g posted Sat, 02 April 2005 at 5:36 PM
I had this same confusion. I went out and bought a Radeon X700 video card hoping to fix my preview render problem. It worked the same as the older Radeon I had. Thanks for the clarification. A follow up question... How can I get hair to render in the openGL preview?? All I see is the mesh of Koz hair just like it was not rendered at all. I thought I saw a preview render posted that had hair rendered like the firefly render but slightly discolored. Any comments will be appreciated. So far I am not seeing much use for the openGL preview... Thanks, Steve
poseadel posted Sat, 02 April 2005 at 11:26 PM
First Thanks to all that helped me. Second, I got the same hair problem, but I got over it! You need to select the hair and check the "Figure Style" make sure it is using the Document Style. Then also check the "Element Style" make sure it is using the "Figure Style" and render away! Adel
