Subject: rendering large files
richarddegouw opened this issue on Apr 02, 2005 ยท 4 posts
richarddegouw posted Sat, 02 April 2005 at 2:27 AM
I have a problem rendering large(r) files in poser. I want a render on 6000 x 4000 pixels at 300 dpi in order to make a print at 50 x 75 cm. The first problem is that in poser 4 renderer (in firefly it will never render, it seams) is the diskspace. I need a minimum free space of something as much as 50 Gb to get it starting the render. The second problem is that when the render is done I end up with a black background with horizontal lines every 5 mm or so, but nothing from the intended render. The file that is created is about 80 Mb in size. How can I solve this or can I render a smaller file and get in into photoshop and change filezsize etc. here or do I then not have the right quality.
Angel1 posted Sat, 02 April 2005 at 10:44 AM
I can't answer the first part but you always want to reduce in your paint program rather than enlarge. Enlarging (from my experience) causes to much pixelation which of course makes it bad quality. Angel1
....Now Bring Me That Horizon....
Send IM | Gallery
richarddegouw posted Mon, 04 April 2005 at 1:25 AM
Thank you, this means that if I want to make every now and then a large print taht I will have to find a way to make them render properly.
Angel1 posted Mon, 04 April 2005 at 6:37 AM
Have you checked the forum posts regarding the horizontal lines? Someone else might have had that problem...... Angel1
Send IM | Gallery
