kaveman opened this issue on Apr 03, 2005 ยท 8 posts
kaveman posted Sun, 03 April 2005 at 7:05 PM
My Hair Nodes no longer load the colour properties. I've checked the files and the colour info's there. It also does it to the standard P6 hair sets. This started after a crash, so something somewhere must be corrupted. I've trashed my preferences, still no change. Anyone else experienced this problem? or better solved this problem. Thanks.
kaveman posted Sun, 03 April 2005 at 8:36 PM
Overwrite, miniumum install: No Change Delete Poser6 Folder, Full reinstall: No Change I don't understand this at all. I used to load the hair with colour fine, now Root_Color Tip_Color don't load. I have just run some more tests and the values are saved ok, just don't load back in. Ok, more tests. Poser's trying to be clever. I changed the colours and deleted the Noise node. Look in the .pz3 colours set and NO noise node in the whole file. Quit Poser, open Pose,r Load test.pz3 file and the colours are set to black and there's now a Noise Node linked to the Hair Node. What the??? I've just wasted 3 hours and now very confused.
PapaBlueMarlin posted Sun, 03 April 2005 at 8:59 PM
Can you post an image to explain this more. I've noticed that some of the hair doesn't really have much of a sheen to it, but that may just be me. I've only had it for a couple days and really haven't had a lot of time to experiment...
kaveman posted Sun, 03 April 2005 at 9:18 PM
PapaBlueMarlin posted Sun, 03 April 2005 at 10:09 PM
There's no noise node in P5 where there should be. I'm just wondering why the colors are different if you loaded the same file. Maybe you should add those colors manually and save as a new file...
kaveman posted Sun, 03 April 2005 at 10:57 PM
hauksdottir posted Sun, 03 April 2005 at 11:03 PM
Have you checked the skull cap?
PapaBlueMarlin posted Sun, 03 April 2005 at 11:12 PM
Carolly, I don't think the skull cap has anything to do with this :) The specular color is usually really light, like a grey or a tan. For some reason, its loading too dark. I've noticed the P6 hair looking dull to me too, but I haven't bothered with it since I've still been just playing with the lights. I've played a bit with some of the P5 dynamic hair in P6 and it looked fine so it tends to make me wonder what is going on. As far as the noise showing up, its supposed to be there. I had it in P5 when I was using the RDNA hair mats.
