DrowVampyre opened this issue on Apr 04, 2005 ยท 8 posts
DrowVampyre posted Mon, 04 April 2005 at 1:30 AM
Hi. I'm trying to make a single FBM that will apply all the effects of several other FBMs. Is there any way to do this? I'm running Poser 6, by the way.
anxcon posted Mon, 04 April 2005 at 2:14 AM
as in creating a face on V3, using a dozen dials then make one dial that apply all the effects as 1? spawn morph target in the menu i think?x_x unless im thinking wrong command......been up too long but yes its possible x_x
DrowVampyre posted Mon, 04 April 2005 at 2:22 AM
Well, sort of. What I'm trying to do is make a single morph dial that wil change standard V3 into a character I created using morphs from several packages, most of which are FBMs themselves.
amberf posted Mon, 04 April 2005 at 3:08 AM
Yes you can. Set the morphs you want to whatever dial setting and then from the Figure menu, click on Create Full Body Morph and give it a name. You'll then have a dial in the 'body' part for that morph combination. Remember to set all the dials back to zero before using the fbm one.
DrowVampyre posted Mon, 04 April 2005 at 3:23 AM
I thought that would work, but when I tried it, the only thing it works for is the face. It doesn't seem to want to apply the other full body morphs.
caulbox posted Mon, 04 April 2005 at 3:29 AM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=2186284
My comments in the linked thread may help.DrowVampyre posted Mon, 04 April 2005 at 5:14 AM
Ah, that helps a bunch. Thank you very much!
unzipped posted Mon, 04 April 2005 at 4:18 PM
bookmark
