skee opened this issue on Apr 05, 2005 ยท 4 posts
skee posted Tue, 05 April 2005 at 7:07 AM
Has any else noticed that when you change figure, from Jessica to james, that the preview window still shows the name of the figure as Jessia? Or for that matter, when you load any figure, like conforming hair or clothes that the name of the figure remains what ever the first figure was called. Is this part of the memory problem? I know you can change the name, but it still seems strange. skee
NOTE: No trees were killed in the sending of this message, but a
large
number of electrons were terribly inconvenienced.
Kingfisher posted Tue, 05 April 2005 at 7:14 AM
I`ve just notice that. I changed the default figure with the WinterQueen & was most surprised to see that she had a mans name. No problem when you delete the original figure. Appears to me to be a bug. Hopefully it will be sorted with the first service pack, which should be out shortly.
skee posted Tue, 05 April 2005 at 7:23 AM
If you go to the hierarhy window to change the name you get a message " This field accepts only numbers between 0- 100"
but it will let you change the name anyway.
very very odd.
skee
Message edited on: 04/05/2005 07:25
large
Poseur posted Tue, 05 April 2005 at 10:05 PM
Attached Link: http://www.curiouslabs.com/article/articleview/1384/1/595/
This is covered in the FAQ on CL's website. See the link. It doesn't look like they see this as being a bug, and the recommended method is to delete the current figure and add the new one, rather than changing one figure to another.
