Subject: Where is the Collision Detection setting in P5?
pookah69 opened this issue on Apr 06, 2005 ยท 5 posts
pookah69 posted Wed, 06 April 2005 at 10:18 AM
Okay, I've read in the manual about this function, and can't find it anywhere. Can somebody point it out to me?
ghelmer posted Wed, 06 April 2005 at 11:40 AM
Hope this helps! Gerard
The GR00VY GH0ULIE!
You are pure, you are snow
We are the useless sluts that they mould
Rock n roll is our epiphany
Culture, alienation, boredom and despair
gammaRascal posted Wed, 06 April 2005 at 11:44 AM
well each object has a collission setting and youll find that in the object parameter dials box under properties. double click any object or body part to open the box. also, the documenbt tools (around the preview pane), the sixth bubble from the top is to turn on collission detection in the preview pane - but dont do that until your posing is done. if you have that turned on and your still posing, it can make posing a bit annoying since poser wil studder slightly if you collide something into something else and its trying to calculate whether or not it should be there. so use the bubble-button after youve finish setting your poses/animation.
pookah69 posted Wed, 06 April 2005 at 2:57 PM
I would think it would be helpful to have collision detection on AS you're posing figures. That way you can avoid placing a figure INto an object instead of ONto an object. No?
gammaRascal posted Wed, 06 April 2005 at 3:39 PM
its just that it can be finiky trying to pose with all the collissions on and having actions 'studder' because poser is calculating. ive noticed anyways.
