tommycros opened this issue on Apr 07, 2005 · 12 posts
tommycros posted Thu, 07 April 2005 at 4:43 PM
I apologize if this seems stupid, but I'm confused about some instructions in Lesson One, "Creating a clown from scratch." On page 78 "To apply a texture map:"
Any help would be appreciated.
Cometsoft posted Thu, 07 April 2005 at 4:48 PM
Maybe we're both stupid, but I'm having the same problem. Do you have the download version or the boxed? Couldn't find that "Texture Changes ..." option either. Was hoping that at least the clown texture would be in the content update.
tommycros posted Thu, 07 April 2005 at 4:50 PM
boxed version. I can't find it, and it's driving me crazy! I couldn't find the paper-airplane file either.
Tirjasdyn posted Thu, 07 April 2005 at 4:54 PM
hrm...those are old Poser 4 tutorials..
Cometsoft posted Thu, 07 April 2005 at 5:03 PM
I've got the downloaded version, so apparently that's not the problem. I suspected they might be old tutorials, because they're not using the default 6 character. Tirjasdyn - do you know if the "Texture Changes Apply to Entire Figure" is an obsolete feature? Thanks
wheatpenny posted Thu, 07 April 2005 at 5:22 PM Site Admin
Those tutorials are left over from Poser 4. I remember doing them. The files were in a folder on the Poser 4 application CD but they seem to have left them out of P6. Strange that theyn kept the tutorial but got rid of the required files.
Message edited on: 04/07/2005 17:23
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
nerd posted Thu, 07 April 2005 at 6:33 PM Forum Moderator
Good grief! They didn't update the tutorial. One more for content updater II. Nerd3D
nerd posted Thu, 07 April 2005 at 6:38 PM Forum Moderator
In Poser 6 Language applying a change to all textures on a prop or figure would go something like this... In the material room right click one of the shader nodes (Like you would know what a shader node was at this point in the tutorial :-P ) Pick Select all Right click again Pick apply to all Click OK Shift click the "remove detached nodes" Wacro. This does a bit more than apply the texture change, it copies the entire material setup, a bit more power full than the Poser 4 "apply changes to all materials option" Nerd3D
Cometsoft posted Thu, 07 April 2005 at 8:15 PM
Thanks Nerd3D, that also makes it a lot easier to apply a color to everything. In the tute you had to pick everything and use the color tool on each item. Wonder if it's even worth continuing with that tutorial? Maybe I should wait for something more current.
tommycros posted Thu, 07 April 2005 at 8:25 PM
Thanks everyone.
Shadow_Fyre posted Thu, 07 April 2005 at 9:35 PM
Attached Link: http://www.curiouslabs.com/filemanager/list/updates/130/132/134/?sbss=300
There are updates for the tutorial at the CL website.nerd posted Thu, 07 April 2005 at 9:50 PM Forum Moderator
That just supplies the missing bits for the existing tut. The whole thing needs to be re-written using P6 language. Nerd3D
