Subject: The Tailor
Acadia opened this issue on Apr 08, 2005 ยท 12 posts
Acadia posted Fri, 08 April 2005 at 8:29 PM
I was told I could use "The Tailor" to help me fit clothes to my figures. But I'm stuck. It says to import the figure with the morphs, which would be the base figure I'm using, V3. Only I never use Vicky as she is, I always use a character addon because I think Vicky "out of the box", is rather homely. How do you import the actual figure you are using? V3 with the character addon injected into it? I'm trying to fit an outfit to V3 that has a character addon, and can't. There just aren't enough dials, or the right kind of dials to expand the bodice to fit the breasts. It's sitting too low and shows the nipples, but I can't expand the material upward to cover that. How do you use Tailor for something like this? Also, I was told that Tailor could help me fit clothes to a sitting character? How do you do that? Is there a tutorial out there that helps walk a newbie through the procedure?
plmcelligott posted Fri, 08 April 2005 at 8:34 PM
After adding your morphs in Poser, save your Vicky character to the Figures library. That will create a CR2 file with the necessary morphs dials. You can then load this file, rather than the basic Vicky, into Tailor. Don't know about the sitting thing.
Acadia posted Fri, 08 April 2005 at 8:57 PM
Ok, I opened Poser, injected Vicky with the character addon morphs, then saved her to the library in the "Poses" folder, and I can see her, but can't use the figure. The only symbol at the bottom of the library is the minus ( - ) one, and I don't know how to get that newly injected figure into the pose window. Double clicking doensn't work either.
xantor posted Fri, 08 April 2005 at 9:25 PM
Save the figure into of of the character libraries, you need the cr2 for the tailor to use.
onimusha posted Fri, 08 April 2005 at 9:28 PM
Attached Link: http://www.daz3d.com/support/tutorial/index.php?id=967
Get a refund and use magnets... here's a great tutorial... I returned the tailor, used the info from this tutorial to learn magnets really well, and never regretted it...
nruddock posted Fri, 08 April 2005 at 9:31 PM
You should have saved to the "Figures" library, this will create a CR2 (with the morphs), which is what the Tailor needs.
However when you do this, Pose will unhide all the unused morph dials, and this can be fixed by using the DialCleaner from DAZ.
Acadia posted Fri, 08 April 2005 at 9:38 PM
Ok,that helped, thanks :)
Actually, Tailor does read .crz files. I was able to open the compressed figure without a problem.... sweet :)
I tried that tutorial for magnets yesterday and got all mixed up with it. Besides, it won't help me fit clothes to a sitting figure. All my figures are standing because I can't fit their clothes to their bodies and I don't think Magnets will help me with that.
Message edited on: 04/08/2005 21:43
Message edited on: 04/08/2005 21:50
onimusha posted Fri, 08 April 2005 at 10:43 PM
Actually magnets can do anything. I use them all the time on a variety of poses...
Tucan-Tiki posted Sat, 09 April 2005 at 1:32 AM
I used tailor and clothes convertor, Clothes convertor is much better 2.2 version allows you to do the same thing and do a bath conversion of all the other clothes in your characters clothing directory, The batch conversion converts all the cloths for you to fit your morphed characters. With tailer you have work at it. With clothes convertor you can even import a bone structure to a new garmnet from a similar garment. You can also do editing directly to the garment to morph it to fit characters or alter its shape.
randym77 posted Sat, 09 April 2005 at 6:49 AM
The Tailor is very quick and easy. I use it a lot. I have Clothes Converter and have been known to use magnets when I have to, but they are much more difficult than the Tailor.
The Tailor doesn't work all the time, but it works well enough that it's worth having, IMO.
Message edited on: 04/09/2005 06:55
Acadia posted Sat, 09 April 2005 at 9:23 AM
Where do you get Clothes Converter? I have trouble with all of Vicky's clothes in anything but a standing position,and even then sometimes if a leg is sticking out as in a dance pose. I am not a patient person, and will get deeply frustrated having to go in and alter one piece of clothing at a time. Ugh! Batch converter sounds much better.
randym77 posted Sat, 09 April 2005 at 9:27 AM
Clothes Converter is sold at DAZ.
