MAW3D opened this issue on Apr 09, 2005 ยท 4 posts
MAW3D posted Sat, 09 April 2005 at 4:32 AM
Just wanted to ask a few others if they do encounter the same problem as I do. Its the following issue: Setup, for example, the angelfish - animate a bit the body and then set the render engine to sketch - now animate it to a sketch animations (do at least 60 frames). I have the following problem with that -Ive used the Cinepak codec (others as well), but it only renders till frame 41 - and then P6 freezes (have to shut it down through the task manager). I have tried the same with the Toonimal Frog from DAZ - same problem. Then Ive tried to animate it with the FireFly render engine and everything was fine. Rendering only 1 frame with the sketch, everything is fine - but at frame 40/41 it "kicks out" sigh Does anybody have the same problems? Thank you for your feedback! Oh .. Ive noticed also, that loading different Runtimes with P6 really takes a heck of time - time was shorter with P5. Anybody?
