darkness_02 opened this issue on Apr 09, 2005 ยท 6 posts
darkness_02 posted Sat, 09 April 2005 at 1:38 PM
You imagination is your only limitation.
Check out Dark Design for freebies for your own artwork.
Kemal posted Sat, 09 April 2005 at 2:25 PM
Those "legs" should definetly be thicker, not bad for a start, keep us posted :D
jfike posted Sat, 09 April 2005 at 3:36 PM
I can't resist: "that robot could definetly plunge a toilet or two!" Just joking. Good start. I think the feet need pivot points. Also this would be a good "glass walker" with suction points (swivel both legs 90 degrees and add a third leg.) When one leg moves forward, all the weight will be on one leg. The body will have to lean to the side with the forward (or backwards) leg. So animating would be tough to make it look realistic. Maybe make the legs look like they are able to move up and down. That's why the "spider" type robots are so popular -- they look like they would be able to walk. Good luck!
Quest posted Sat, 09 April 2005 at 7:00 PM
LOL@Jfike, same thing I thought right off but I thought they were arms with plunger ends not legs. Darkness, what bit of the robot is this, upper half? Certainly want to see where this is going, very good start. Maybe we should name him Roto-Router Roby? ;)
Mrdodobird posted Sun, 10 April 2005 at 1:19 AM
Hehe. Cool. Hope you keep workin' on him!
vasquez posted Sun, 10 April 2005 at 3:33 AM
ehi nice start! It has something sexy!
