Kemal opened this issue on Apr 09, 2005 ยท 20 posts
Kemal posted Sat, 09 April 2005 at 2:45 PM
Thanks in advance for your input! :D P.S. So far 2 lights in this scene, one outside, one inside(with no shadows, fill light)
Message edited on: 04/09/2005 14:47
lordstormdragon posted Sat, 09 April 2005 at 2:52 PM
I don't seen any lightning, but the image sure looks great!
CrazyDawg posted Sat, 09 April 2005 at 2:58 PM
Kemal, being one that as never tried doing anything like this i can only say you have done a great job. What could set it off and make it look more real is if you added something to the image that could make it look like the light beams and going throw it...something that looks like dust floating around.
Also the left corner of the dresser looks bare, might be an idea to place a potted plant or a statue of some kind on there, maybe add a painting on the wall to break the blank spot up on it just above the dresser.
Just some ideas for you to look at. Others may think of other things.
Message edited on: 04/09/2005 15:00
I have opinions of my own -- strong
opinions -- but I don't always agree with them.
kimpe posted Sat, 09 April 2005 at 2:59 PM
Perfection!
Kemal posted Sat, 09 April 2005 at 2:59 PM
Thanks, I actually meant to ask how lights are working in this scene, lol :P
lordstormdragon posted Sat, 09 April 2005 at 3:28 PM
(grins) I know, just messin with you... Volumetrics would be nice, in this one. But I think it's wonderful how it is, as well! (Note to self : just because we can do volumetrics doesn't mean you have to use it all the time!)
madmax_br5 posted Sat, 09 April 2005 at 3:46 PM
Looks great so far! Reduce your material's ambience to add more impact and mood, put some negative lights in the corners at low intensities. The blinds should be brighter with that much light hitting them...try adding a square parallel light facing them from the outside, move it real close, set it to ranged falloff on like a setting of 5 or 6, then crank the intensity. That should add a glowinbg effect... I don;t know if you can change this but the blinds are too straight. Bend a few of them to make it seem more realistic.
Erlik posted Sat, 09 April 2005 at 4:15 PM
Well, it looks quite great but there's a couple of things feeling wrong. That light on the wall looks like it's coming from a bare window. Likewise the light on the right side of the drawers. Is that something from the unseen door/window? Even if it is, it looks like an error. Then, I agree with madmax about the intensity. Weirdly enough, it appears that the texture of the wall is continuing on the radiator. Shadows?
-- erlik
madmax_br5 posted Sat, 09 April 2005 at 6:44 PM
Quest posted Sat, 09 April 2005 at 6:49 PM
Kemal, this is fantastic! A few things here: Shouldnt that shadow on the wall be further to the left of the lamp? If you follow the light reflecting off the front of the lamp and how in lines up with the light coming in through the window, it doesnt seem to line up with the shadow on the wall. The way it is now, at that angle you shouldnt be able to see as much of the lamp shade on the wall. I think I see light rays streaming across the image but it doesnt seem to line up with the visible window but a second, unseen widow towards its right is inferred. I see the inferred windows light reflection on the floor, so maybe the rays should go beyond the right side of the visible window to indicate theres were the light rays are coming from. I agree that the colors should be a bit more intense, maybe the haze is up a little too high? And as a side note, I have blinds and none are bent, but then, I could be anal that way. Maybe the rustled hint of a small area rug would suffice in place of bent blinds. Nice work!
pauljs75 posted Sat, 09 April 2005 at 7:34 PM
I like the bottom left one in #9. However, something has to be done about how the light appears when it hits the wall. It's way too bright there. Perhaps a strategically placed negative light might work.
gregsin posted Sat, 09 April 2005 at 9:47 PM
Looks great to me, I think the light on the wall is from the blinds being away from the window.
GROINGRINDER posted Sun, 10 April 2005 at 12:33 AM
I love your original, but madmax has certainly added some life to the party with his postwork.
vasquez posted Sun, 10 April 2005 at 3:31 AM
Near perfection Kemal! I'd remove the light in the bottom right spot on the floor, like other said looks like an error, play a bit with contrast as madmax suggested and add some highlights here and there (on the handles or radiatros for example)
ysvry posted Sun, 10 April 2005 at 3:38 AM
add a childs toy too the floor to get in some bright colors as its very brown now.
Dann-O posted Sun, 10 April 2005 at 3:39 AM
Great image I woudl put soemthing up on the dresser there always is soemthing up there. Great lighting I don't honestly know which one to go with. The original looks like there is a lot of dust in the room.
The wit of a misplaced ex-patriot.
I cheated on my metaphysics exam by looking into the soul of the
person next to me.
Kemal posted Sun, 10 April 2005 at 3:46 AM
Thanks for all the replies, guys, original image was actually rendered with volumetrics on set to quality=5, thats why there is a lot shadow "textures" in the air, I'll try to do much loger render to see is there gonna be lot of difference :D
lordstormdragon posted Sun, 10 April 2005 at 4:55 AM
Volume quality places a big part in that stuff, I totally see what you mean. Sometimes you can't get rid of the artifacts realistically, anyways. This flower used a light dome to make the soft shadows, and one volumetric spotlight set to 30 even, and I still got some silly shadows... Took forever to render to, those tough little volumetric-demons are ruthless... (oh yeah, in number Nine, I like the one on the bottom right myself...)
Message edited on: 04/10/2005 04:57
TheBryster posted Sun, 10 April 2005 at 6:57 AM
This is a great image. Wonderful lighting in all versions. My only problem, and I keep doing this, is that I spot things that are wrong from a technical viewpoint. That is, I think the top 2 radiator pipes shouldn't be there.....0.02p
MoonGoat posted Sun, 10 April 2005 at 1:01 PM
Lighting is wonderful whatever version you go with. I think that the radiator texture should be a bit less ambient though.
