Subject: Shade 7 designer LE Serial # help!!
GothKurlz opened this issue on Apr 11, 2005 ยท 7 posts
GothKurlz posted Mon, 11 April 2005 at 1:02 PM
installed it and tried to put in the serail # that was emailed to be but it keeps telling me it's an Innocret. does anyone have any ideas on what i should do or who i should email? thanks ---Essie
DCArt posted Mon, 11 April 2005 at 1:26 PM
Attached Link: http://www.curiouslabs.com/article/articleview/20/1/289?sbss=289
>> does anyone have any ideas on what i should do or who i should email? Send an email to Curious Labs. All of the various contact information is on the page listed at the URL attached here.
Natolii posted Mon, 11 April 2005 at 1:27 PM
Make sure you are using zeros "0" instead of the letter "O". Always makes sure to use the Hyphens.
amberlover13 posted Mon, 11 April 2005 at 1:28 PM
I eventually, after emailing CL 4 times, called tech support at CL and finally got one. That would probably be your best bet. Another thing to try is to do a cut and paste of the number you got and see if that works. That's the only way I can make my P6# to work.
GothKurlz posted Mon, 11 April 2005 at 3:50 PM
thanks all, i had copy and pasted it but it kept telling me the same thing. looks like I should just call them and see what they can do. thanks again for your help.---Essie
Berkley posted Mon, 11 April 2005 at 6:44 PM
If you copy and paste the number from the email try backspacing 1 or 2 times (if that erases the last number just retype it back in).
I was having problems with mine doing copy/paste and then discovered it was adding extra spaces in, even though you couldn't see them.
Once I backspaced it worked fine.
GothKurlz posted Mon, 11 April 2005 at 9:03 PM
thanks I'll give it a try
