raf1 opened this issue on Apr 11, 2005 ยท 3 posts
raf1 posted Mon, 11 April 2005 at 9:39 PM
Greetings, I'm creating a lighthouse animation whereby the lighthouse light (located offshore in ocean)rotates and illuminates the surrounding scenery. The problem is that when the light shines upon low clouds on the horizon, it creates a "light shining on a flat wall" effect. I've tweaked intensity, fall-off and such and I'm getting closer but would accept any advice available. No use reinventing the wheel! Thanks. raf
Polax posted Tue, 12 April 2005 at 12:57 AM
Depending on which version of Vue you have. 4Pro, 5E+light module, 5Infinite give access to 'light attenuation settings' (edit the light's shadows and lighting) there, you can tune the distance to which the light can travel before fading out. Also, quadratic spots have a shorter range than regular spots. Paul
raf1 posted Tue, 12 April 2005 at 12:11 PM
Hi Paul - thanks for your response. I have V5I and will dig a little deeper into the settings - thanks for the heads up on quadratic spots. I may be closer to my desired result that I thought. raf
