Eroticartist opened this issue on Apr 12, 2005 ยท 5 posts
Eroticartist posted Tue, 12 April 2005 at 11:24 PM
I have PS7 and I've loaded in so many brushes that they disappear off the right edge of the screen and I can't get to them. Any ideas on how to maybe minimize the brush screen? I can't seem to grab any corners either. Thank you!
DJB posted Tue, 12 April 2005 at 11:50 PM
Make some new folders for them I guess.Put only a few in each folder. Maybe 10 that's all I can think of.
"The happiness of a man in this life does not consist in the
absence but in the mastery of his passions."
Hoofdcommissaris posted Wed, 13 April 2005 at 2:45 AM
If you press the little triangle in the brush palette, you can choose a smaller preview, if you didn't do that already. Otherwise organising them in smaller groups (like 'hair' and 'bushes') is the best idea. You can save your brushes to do so, but they will become one big file. I don't know if you have acquired them through the years or made them yourself. Each brush set can be chosen from the same triangle thingy as mentioned above. The list will appear below the other menu items. If there is not anything, be cautious, you could loose all your brushes by resetting the palette to the standard brushes! First save your current set ("EroticBrushes"). And then start eliminating brushes you don't want in the first set you are going to save ("hair"). When only hair brushes are left, save them as HAIR. Reload the set EroticBrushes and continue to eliminate others and save. It is a lot of work, but the only solution if you only have one massive collection. In Photoshop CS there is a function to manage your brushes (and a lot of other things) on the bottom of the 'edit' menu, that allows you to select multiple brushes to eliminate. But I do not know if that was already in PS7... That could save a lot of time... Good luck!
Eroticartist posted Wed, 13 April 2005 at 7:37 AM
Thank you! (:
AlphaRed posted Tue, 19 April 2005 at 9:03 PM
lol i was having the same exact problem as of late...thanks for the help I'll try those ideas out..
