Angelouscuitry opened this issue on Apr 13, 2005 ยท 5 posts
Angelouscuitry posted Wed, 13 April 2005 at 8:09 PM
When I go to my Gender Dial, and Open the Triangualar Drop Down, I then set the Value, Min., and Max. to 1, click OK, and then toggle on the little Lock icon, but when I hit the random face button a few times the faces do'nt remain female? I also tryed toggling both it and the master lock for the category Gender is in, but that fails also?
xantor posted Thu, 14 April 2005 at 2:03 AM
The locks don`t seem to work, you could just change the dial to make the head female again after making the random face.
Angelouscuitry posted Tue, 19 April 2005 at 5:41 PM
xantor - What speed computer are you using, if you do'nt mind me asking? I've used this with a 700Mhz Celereon, but do'nt remember running into this problem, allthough currently I'm using an older 400mhz Desktop. I've accomplished much more than I'd hoped for, and still hope power is'nt an issue. = )
xantor posted Wed, 20 April 2005 at 5:18 AM
It is a 1.1 gigahertz computer. It is poser 5 that I use. With my copy, the face usually reverts to the male type face, but manually changing the dial usually works.
Angelouscuitry posted Sat, 23 April 2005 at 11:17 AM
