Subject: poser 6
stefanino opened this issue on Apr 16, 2005 ยท 3 posts
stefanino posted Sat, 16 April 2005 at 12:09 PM
Hi! I have a little question about poser 6. When i move the cam around the figure with the trackball or i use the wheel to set the dials, the figure is becoming made of cubes :)) is normal this? in Poser 5 this was not happening. HOw can i fit clothes after i have posed my figure and these clothes are not fitting the figure? Thanks very much and happy rendering Stefano :)
DCArt posted Sat, 16 April 2005 at 12:29 PM
When i move the cam around the figure with the trackball or i use the wheel to set the dials, the figure is becoming made of cubes :)) is normal this? in Poser 5 this was not happening. Check what your settings are for Display > Tracking. It defaults to Fast Tracking, which changes to boxes when you are moving the camera. It sounds like you might be looking for Full Tracking, which displays the figure when you move the camera.
Fazzel posted Sat, 16 April 2005 at 1:11 PM
When i move the cam around the figure with the trackball or i >use the wheel to set the dials, the figure is becoming made >of cubes :)) is normal this? in Poser 5 this was not ?happening.
Actually it does happen in Poser 5 if you have it set
up to do that. Like Deecey says, you have to set up
your tracking mode.
As far as the clothes, if they are conforming clothes you
need to go to Figures|Conform To... and then select the
figure you want the clothes to conform to. If they are
dynamic clothes you need to take them to the cloth
room and run the simulation to get them to fit.
Message edited on: 04/16/2005 13:13
