Subject: CRZ to CR2????
Starkdog opened this issue on Apr 16, 2005 ยท 5 posts
Starkdog posted Sat, 16 April 2005 at 2:17 PM
Hi guys, I've made some clothes for Jessi and Katie, and am attempting to conform them, but one problem. How do I go about converting the CRZ to a CR2 without messing things up? Is it as simple as renaming the CRZ in a text editor? I checked the preferences folder, and compressed files are unchecked, so I'm kinda confused here. Thanks for the help, -The Starkdog
mateo_sancarlos posted Sat, 16 April 2005 at 2:27 PM
Unzip it.
DCArt posted Sat, 16 April 2005 at 2:33 PM
The option to compress or not compress files takes place when you save files to the library. So, there are actually several ways that you can uncompress it ...
(1) Open the CRZ file in WinZip (or similar utility), and extract the CR2 to the same folder.
(2) Choose Window > Python Scripts, and choose the Utility Funcs > UnCompress Files option to uncompress all of the files in a selected folder.
(3) Empty the document window; load the CRZ into your scene, and resave it to the library while the "Compress files" option is not checked. With any of these options, it might not hurt rename or save the CR2 with CR2 in the file name somewhere, to distinguish it from the original CRZ compressed version. Also, the CR2 and CRZ versions of the library file will still call the original OBZ file, so if you also uncompress the OBZ to OBJ you'll have to edit the CR2 version.
Message edited on: 04/16/2005 14:38
nruddock posted Sat, 16 April 2005 at 2:39 PM
Load and resave in the figure library under a different name to get an uncompressed version, or run the decompression script from the Python palette on the relevant directory, with delete original files unchecked.
(Turning the flag off doesn't uncompress files, it just mean that any files saved while it is off will be saved as text).
Starkdog posted Sat, 16 April 2005 at 2:47 PM
WOWWWWWWWWWW!!!! Thanks for the quick replies! I will definently try these out. You guys are the best. -The Starkdog
