Subject: How to change the "Image Map" name in Poser5 ...
geep opened this issue on Apr 20, 2005 ยท 2 posts
geep posted Wed, 20 April 2005 at 7:17 PM
This is a special reply for MaryK.
In Poser5:
  1. [menu] "Edit" ---> "General Preferences..."
  2. UNcheck "Use file compression"
  3. Go to "Material Room"
  4. Load the Material on which you want to change the "Image" names
  5. Save the Material as "Test_Material" (or other name if you want)
    (this makes a copy of your original - unless you use the same name)
    (exit Poser)
  6. Look in:
    C:Program FilesCurious LabsPoser 5Runtimelibrariesmaterials
    ... for the "Test_Material.mt5" file.
  7. Use a word processor to open the "Test_Material.mt5" file.
  8. Scroll down and find this text (below) ... for each image map that you have:
    node "image_map" "Image_Map_x" {
    . name "CHANGE THIS NAME"
  9. Change the name where it says "CHANGE THIS NAME"
  10. (re)Save the "Test_Material.mt5" file.
    ... end of instructions ...
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
pteryx posted Wed, 20 April 2005 at 10:11 PM
YESSSS! I wasn't sure which instance (or instances)to change in that bunch....Thank you!
