davidryuen opened this issue on Apr 21, 2005 ยท 8 posts
davidryuen posted Thu, 21 April 2005 at 2:58 PM
DVcreator posted Thu, 21 April 2005 at 4:08 PM
Change the scale? R
davidryuen posted Thu, 21 April 2005 at 6:02 PM
I can expand the contrails so that the pattern is not that evident but the pattern reamins the same. And the contrail effect is lost.
Poseur posted Thu, 21 April 2005 at 8:34 PM
What cloud pattern do you have loaded in your atmosphere? This looks like the "Busy Aliens" pattern. "Airplane Trails" is a lot more subtle.
(To change the pattern, go to the Atmosphere editor, select Clouds, right click the preview picture to load a material, and look under Clouds - Other Clouds.)
sittingblue posted Thu, 21 April 2005 at 8:34 PM
Have you tried going into the function editor for the clouds material and changing the wavelength of the lines function (either the x or y to zero)?
Charles
davidryuen posted Thu, 21 April 2005 at 10:03 PM
That is a snapshot of Airplane trails with a scale of .10.
I made progress by setting the X value of the function editor to 0. But the lines were now symmetrical in one direction, as if a whole squadron of jets flew side by side.
It's quite easy to reproduce - just add the Airplane trails clouds - I'm not doing anything complicated.
Poseur posted Fri, 22 April 2005 at 9:15 PM
The contrail effect is mostly created by the Lines noise node that's connected to the Transparency in the function editor.
We don't have much control over how the pattern is repeated because it's a noise node. So try replacing it with an image map consisting of a fuzzy, thin horizontal black line on a white background. Vue repeats the image map across the sky, but you can adjust the UV scale to achieve a single contrail like the above example.
Poseur posted Fri, 22 April 2005 at 9:23 PM
With a little work on the image map, the blending of the noise node and the UV mapping, I hope you can use this idea to create the effect you're looking for.
