Forum: Carrara
Subject: composite: Where's the matte shader???
Exyled opened this issue on Apr 22, 2005 ยท 5 posts
Exyled posted Fri, 22 April 2005 at 12:22 PM
How do you create a matte shader for receiving shadows in carrara? I tried to take a highway scene, and I want to put my logo sitting in one of the lanes. Obviously I need to create a shader that's see through, but will still receive shadows. any help would be great. thanks. Shaun
MarkBremmer posted Fri, 22 April 2005 at 3:30 PM
Carrara uses a little different scheme for that. Instead, you change the Lighting Model in the texture room. The object will now only show up when a shadow is cast on it and uses whatever colors and textures you designate in the shader. Usually, you simply color the object with a dark gray or black since that is what most shadows look like. But, for colored shadows you can use different colors. Kinda cool. Make sure to uncheck "Cast Shadows" for the object in the Assembly Room. Mark
ewinemiller posted Fri, 22 April 2005 at 5:30 PM
Mark,
Very interesting, I never noticed that the built in Shadow Catcher would color the shadow using the sub shader. Hmmm, guess I have a little more work left on the GI Shadow Catcher...
Regards,
Eric Winemiller
Digital Carvers Guild
3D plug-ins for Carrara
http://digitalcarversguild.com
Eric Winemiller
Carrara and LightWave plug-ins
Kixum posted Fri, 22 April 2005 at 7:49 PM
Yes it does. Whatever the shader is on the object is what will show up. This is just a simple plane with a rough sandy colored orange texture that had to be matched to the image. -Kix
-Kix
Exyled posted Fri, 22 April 2005 at 10:18 PM
Thanks alot...i appreciate this...
