stella6488 opened this issue on Apr 29, 2005 ยท 5 posts
stella6488 posted Fri, 29 April 2005 at 5:54 AM
wabe posted Fri, 29 April 2005 at 6:16 AM
Any reason why you haven't updated to the actual version of Vue 4? 4.22 is the newest when i remember it right. You should try that as #1. You haven't said from which format you imported into Vue. obj? 3ds? lwo? Maybe you try other formats as well. As well you can change the mapping method here. I know - as we all can see every day in the gallery - that the import works fine with Poser models. Including the correct positioning of the maps. And with 3ds too - i use that a lot, even when my Vue 4 days are over a long time ago.
stella6488 posted Fri, 29 April 2005 at 6:26 AM
yep it was an obj file, will also try to locate teh 22 update. thanks a lot for the quick response. PT..
stella6488 posted Thu, 05 May 2005 at 2:15 AM
Updates to 4.22, still same result, will keep at it, thanks Wabe..
phenom01 posted Thu, 05 May 2005 at 9:14 AM
Hi. Depending on how you saved your map, you may have to flip or rotate the image. Most often it is just a matter of flipping the image vertically. First, try replacing the 1.000 in the "Picture Scale Y" edit box with -1.000. HTH
Message edited on: 05/05/2005 09:18
