AceC opened this issue on Apr 30, 2005 ยท 3 posts
AceC posted Sat, 30 April 2005 at 11:58 PM
Hello,
Just started playing around with networked rendering using Bryce Lightning. However, I can't seem to find anywhere to change the image size and/or DPI settings of the final image... Is there any way to set these for a render without changing your workspace settings (as there is when rendering to a local disk)? This would apply to both rendering an animation and networked rendering.
Message edited on: 04/30/2005 23:59
drawbridgep posted Sun, 01 May 2005 at 9:33 AM
With animations, I tend to set it up at a reasonable size to work with and then when I'm ready to render, shrink it down in the workspace to whatever size I'm going to animate at. But also if you click on File, Document resolution, you can set a different document resolution to the render resolution. Maybe that will work for you.
AceC posted Sun, 01 May 2005 at 12:11 PM
Thanks, that'll work. Although in my case I'll generally be increasing the document size, since I'm working with still images (just network rendered).
