lastexplorer opened this issue on May 01, 2005 ยท 4 posts
lastexplorer posted Sun, 01 May 2005 at 10:32 AM
dvisuals posted Mon, 02 May 2005 at 2:50 AM
What version of Poser are you using? What app did you use to model the boots? Did you check the normals direction after you mirrored/copied from the original? They should all face out. The polys may have too many sides in the copy. Poser doesn't like polygons with more than 4 sides (n-gons.) Double sided polys can also cause holes in the mesh or black spots. Strange things can happen during import/export writes. Don't know about the toe stretch. Was everything zeroed? Hope this helps but I'm just speculating.
EnglishBob posted Tue, 03 May 2005 at 6:36 AM
Since the boots' toes aren't in the same place as Aiko's toes, the joint parameters will need adjusting. Just shift them down until they coincide with the new toe positions.
nomuse posted Wed, 04 May 2005 at 12:39 AM
And nice modelling....this should look very cute when finished.
