Subject: UV from OBZ?
TigerD opened this issue on May 04, 2005 ยท 7 posts
TigerD posted Wed, 04 May 2005 at 8:40 AM
Trying to make textures for Alphaman Suit in P6. UVMapper unable to read Obz file. Is there any way to unzip this to obj format?
PhilC posted Wed, 04 May 2005 at 8:47 AM
Yes, go to File/Run python script and select
RuntimePythonposerScriptUtilityuncompressPoserFiles.py
kawecki posted Wed, 04 May 2005 at 9:43 AM
You can also decompress obz, crz, ??z with WinRar.
Stupidity also evolves!
kaveman posted Wed, 04 May 2005 at 4:15 PM
Change the file extension to .zip, unzip it then change it back to .obj.
odeathoflife posted Wed, 04 May 2005 at 4:30 PM
if you go the .py mthod make sure you say to delete the zipped ones cause if you don't then you will do like me and have 2 of everything installed which in turn takes a lot of time to delete by hand :)
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
Francemi posted Wed, 04 May 2005 at 7:26 PM
You can also unzip it with Winzip (at least with v8+). I right-click on it in Windows Explorer and I choose OPEN WITH - Winzip. Then I drag it from Winzip window to the folder I want in Windows Explorer.
France, Proud Owner of
KCTC Freebies
Countach posted Thu, 05 May 2005 at 5:56 AM
You can also export it from Poser in .obj format. Click "Save as morph target" box in the export dialog box.
