LostinSpaceman opened this issue on May 04, 2005 ยท 5 posts
LostinSpaceman posted Wed, 04 May 2005 at 3:29 PM
Is it just me or is Jame's Base Hair folical prop too low res to be any good? I can't seem to get his hair thick enough to look like a full head of hair unless I raise the folical count well over 100,000 and then I start getting the out of memory error messages.
destro75 posted Thu, 05 May 2005 at 1:21 PM
Are you using a skull cap first? You need to put on a skull cap then the hair for it to look full. Then you dont need quite so many hairs.
LostinSpaceman posted Thu, 05 May 2005 at 1:24 PM
I was under the assumption that the follicle hair prop WAS a scullcap!
destro75 posted Sat, 07 May 2005 at 7:46 AM
Ah, I just found what you are talking about. I never use the Follicle sets. There is a folder in the P6 Hair directory called SkullCaps. I use the caps from there. They work pretty well for me. By the name, and this is an assumption, a follicle cap would have individual hairs on it. I would think it would be more of a base for creating strands, rather than a true skullcap.
LostinSpaceman posted Sat, 07 May 2005 at 1:09 PM
