Subject: Dynamic Hair - first steps - need advise
MarcioAB opened this issue on May 05, 2005 ยท 3 posts
MarcioAB posted Thu, 05 May 2005 at 12:08 AM
The link below has a 2.5 MB video in wmv format...
http://pws.prserv.net/marcioab/v3-1.wmv
...created with a few polygons of Poser6 Dynamic hair with the following settings:
Do collision: YES
Gravity: -0.0005
Spring Strenght: 0
Air Damping: 0.5
Spring Damping: 0
Bend Resistence: 0.5
Position Force: 0
Root Stiffiness: 0.05
Root Stiffiness Fallof: 0.33
Hair Density: 10,000,000 (4771 hairs)
Verts per hair: 10
This was the best I got to avoid the hair keeps jumping or moving when it should not.
Question: Can you give some advise on those parameters ?
Thank you.
operaguy posted Thu, 05 May 2005 at 12:53 AM
can you give times, both for the calculation of the dynamics and to render?
MarcioAB posted Thu, 05 May 2005 at 9:18 AM
The dynamics calculation is very fast: 15 seconds for all 120 frames. The render is far more slow: 38 minutes for all 120 frames (19 seconds per frame) Render set in Auto (the one associated with Min shading rate = 1.25), 532x566 in size, codec MS Video1 @ 100%. CPU = AMD64 +3200
