I made a set of sandals for Elle, made the strap rFoot and the sole rToe, so that the sandal will flex like it naturally should. I used Quick conform using Elle-Lo.cr2 as the donor, and made a new cr2. I went and loaded Elle-Lo, and the sandal. I went to conform the sandal, and it conforms to her ankle, not her toes and foot. What the heck is going on here? Attached is a pic of what is happening. Another strange thing, is that somehow, the normals on the sole are reversed, when they were just right prior to making the cr2 file. Is my computer possessed or am I doing something bass ackwards? Thanks, -The Starkdog
If you adjust the joints in the joint editor you should be able to make the shoe fit, if the sole is a seperate group then select it in the setup room and reverse the normals.
