drackliffe opened this issue on May 08, 2005 ยท 5 posts
drackliffe posted Sun, 08 May 2005 at 7:42 PM
Anyone having problems saving a figure with multiple conforming figures to the library and then using it? I've saved a few figures with conforming cloths & hair to the library but when I go to use them later they are all screwed up. Hair down around the chin. cloths don't fit and won't adjust to fit either. Have to start from scratch. Is this a known bug and is it being addressed? Thanks.
acanthis posted Mon, 09 May 2005 at 1:26 AM
Go to Edit->Preferences->Misc and disable the option to use binary morph files. Then you'll have to recreate the figure and re-save it to the library. This is a very, very nasty bug that's tucked away in 6 and has caused me a lot of trouble. I used to just disable it before adding figures to libraries, but I've since found that this vile bug can also make its presence known when saving a scene file; as in a recent case where Stephanie Petite lost all of the expression morphs because they were arbitrarily dropped from the .pmd file by Poser 6
drackliffe posted Mon, 09 May 2005 at 10:20 AM
Thank you for the advise. I'll try it when I get home tonight. Hopefully they fix this with the patch.......
Insom_Nia posted Mon, 09 May 2005 at 10:53 AM
Yes, I found out about that bug the hard way too! All my custom morphs get regularly screwed up.... The idea with saving space with this new pmd format is a good one but now I'm back to the old ways till they find a solution.
drackliffe posted Tue, 10 May 2005 at 8:58 AM
It worked great!!! Thank you very much.
