vulcanccit opened this issue on May 08, 2005 ยท 11 posts
vulcanccit posted Sun, 08 May 2005 at 9:17 PM
I purchased Bryce 5.5 a week ago and have been going through the tutorials. I did the one with the 2 terrain mountains and then the negative terrain that creates a lake bed then you fill it with water. I like how that turned out, but I want to add an ocean behind the 2 mountains. This would then look like maybe you are up behind these to mountains but then looking down on an ocean. So I tried to added a second negative "ocean bed"...and fill it with water too. however this new water just spreads over onto the lake water. I tried to move the Y down and its either level with the lake water or not visable at all. If it is visable then it spreads all over the place. Is there a way to do what I am trying?
ysvry posted Sun, 08 May 2005 at 9:51 PM
the water is an invinitive plain so it will always show trough , you could make a cube and give it a water 3dtexture make it big though.
foleypro posted Sun, 08 May 2005 at 9:51 PM
Screen pic please...
vulcanccit posted Sun, 08 May 2005 at 10:00 PM
foleypro posted Sun, 08 May 2005 at 10:23 PM
Ok... Group the Mountains and trees and the Lake together and then Raise up a Little above the Ground Plane,Then select the Ground Plane and add your Water Material... For the Lake use a 2D plane and just position it where the Lake is and no Bigger..I will show you what I mean...BRB..
foleypro posted Sun, 08 May 2005 at 10:29 PM
foleypro posted Sun, 08 May 2005 at 10:30 PM
vulcanccit posted Sun, 08 May 2005 at 10:30 PM
Thats exactly what I want to do! ok i have my homework assignment! heheh thank you!!
foleypro posted Sun, 08 May 2005 at 10:31 PM
vulcanccit posted Sun, 08 May 2005 at 10:43 PM
is the 2d plane you speak of just a ground plane?
foleypro posted Sun, 08 May 2005 at 11:06 PM
Nope the Square in the create Menu... Or use a Box instead....Flatten it and fit it to fit to the Lake..
