cherokee69 opened this issue on May 08, 2005 ยท 47 posts
cherokee69 posted Sun, 08 May 2005 at 9:53 PM
Starkdog posted Sun, 08 May 2005 at 10:28 PM
WOWWWWWW!!! That looks nice Cherokee69. Keep up the good work. It will look really nice when you get it finished, and placed with the garage and chicken coop. I'm sure Dr. Geep is beaming with pride in you. Just out of curiousity, how "heavy" is the resulting obj file? I want to create a house too, but was wondering if making it in Poser would result in a smaller obj, than in a modeler like Silo, Max, etc? Thanks, -The Starkdog
anxcon posted Sun, 08 May 2005 at 11:33 PM
depends how detailed you model it the above appears to be every beam used in the frame of a real house and then adding walls? dont quite see point as the beams would be covered up? unless im wrong but whether its done in poser or another modeller, the obj file would be same size, its the same data, unless the model is changed into something different
ChuckEvans posted Mon, 09 May 2005 at 5:50 AM
Looks like real framers have been at work!
dirk5027 posted Mon, 09 May 2005 at 6:13 AM
great job
artistheat posted Mon, 09 May 2005 at 6:48 AM
Awesome Job,It's going up very nicely.I hope you hire a good Electrician..lol..
cherokee69 posted Mon, 09 May 2005 at 6:49 AM
Message edited on: 05/09/2005 06:52
geep posted Mon, 09 May 2005 at 6:54 AM
That's the "magic box?" ................ WOW!!!
You're making it do things that I had not even imagined.
Be careful though, I'm not sure that it's fireproof. ;=]
Lookin' (very) good !!!
cheers,
dr geep <---------------- beaming with pride
P.S. What, you haven't worn out that measuring prop yet?
Maybe it's time for a new one, hint, hint. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
cherokee69 posted Mon, 09 May 2005 at 7:07 AM
" That's the "magic box?" ................ WOW!!!" Yeah it sure is Doc...well, there are alot of them in that chimney..plus..another one that I made that has 4 morphing sides. Created that one from a magic box and your pyramid tut.
geep posted Mon, 09 May 2005 at 7:11 AM
You're really getting to be a master Poser builder! ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
cherokee69 posted Mon, 09 May 2005 at 7:16 AM
If it wasn't for your tuts, I'd never have gotten this far.
That 4 sided morphing box is also used for the rafters so I could get the cut ends at the correct angle.
Message edited on: 05/09/2005 07:17
vilian posted Mon, 09 May 2005 at 7:38 AM
O.o Wow, impressive work !
Outdated gallery over at DeviantArt
Fics at FanFiction.net and Archive of Our Own (AO3)
geep posted Mon, 09 May 2005 at 8:37 AM
So, um ......... who says that you can't model with Poser? Huh, huh, huh? ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
cherokee69 posted Mon, 09 May 2005 at 8:44 AM
" So, um ......... who says that you can't model with Poser?" It sure wasn't me.
geep posted Mon, 09 May 2005 at 8:54 AM
Obviously !!!!!!!!!!!!!!!!!!! ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
jancory posted Mon, 09 May 2005 at 10:11 AM
this is looking really great! i love the detail you're putting into it.
here's some humble suggestions to increase the reality of it (from my own building experiences):
chimney shouldn't be centered on the ridge, it should be offset so the ridgepole stays one piece (i see the original was on an outside wall) & i assume you'll be extending it to the ground in the final design.
don't forget nailers for the tin roofing.
some windows in the addition room still need cripple studs above & below.
roof trusses need crossbracing & gable end studs.
but i repeat: this is REALLY looking good. what a great project! kudos to you & to geep for his tutes.
lost in the wilderness
Poser 13, Poser11, Win7Pro 64, now with 24GB ram
ooh! i guess i can add my new render(only) machine! Win11, I7, RTX 3060 12GB
cherokee69 posted Mon, 09 May 2005 at 8:41 PM
Jan, Thanks for the suggestions. I realize there are some things that aren't right but, I'm copying the house that my grandparents built around 1920. The chimney is exactly where it is on the real house....plus, I have good reference...I'm living in it.
gg77 posted Thu, 12 May 2005 at 10:52 PM
Running the ridge beam through the chimney is not a good plan and won't pass Code. I would recommend a program called Chief Architect at http://www.chiefarchitect.com/ for anyone seriously interested in architectural software.
cherokee69 posted Fri, 13 May 2005 at 7:46 AM
Message edited on: 05/13/2005 07:47
geep posted Fri, 13 May 2005 at 8:40 AM
Editorial Note -
Fireplaces were built in the center of a house so that the house would have "central" heating; maximizing the amount of heat that stayed inside the house and radiated in all directions.
A fireplace built on the outside wall of a house will lose some of it's heat to the outside and would not be as efficient.
cheers,
dr geep ... :o]
edited 10/5/2019
artistheat posted Fri, 13 May 2005 at 9:41 AM
I have to say for a house that was build in the 1920 it still looks very strong and sturdy.Your Grandfather did a excellent job:)
jancory posted Sat, 14 May 2005 at 4:29 PM
fantastic!!!! & by gum the chimney DOES run thru the ridge..........& i see you won't need nailers or crossbraces either! keep us posted on your excellent work. this is just amazing for poser.
cherokee69 posted Tue, 17 May 2005 at 10:01 PM
geep posted Tue, 17 May 2005 at 10:15 PM
That's absolutely beautiful !!!
How many (magic) boxes have you used?
I get a commission on each one that gets used, ya know. ;=]
Lookin' really, really good !!!
cheers,
dr geep ... :o]
edited 10/5/2019
cherokee69 posted Fri, 20 May 2005 at 10:36 PM
cherokee69 posted Fri, 20 May 2005 at 10:37 PM
Message edited on: 05/20/2005 22:40
geep posted Sat, 21 May 2005 at 6:56 AM
Ever get it done? ..... Yes, you will. And, when you do, you will have a masterpiece! ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
artistheat posted Sat, 21 May 2005 at 6:58 AM
I'm just watching and waiting to move in..LOL...Keep up the Excellent Work..Very Impressive
cherokee69 posted Mon, 30 May 2005 at 8:57 AM
geep posted Mon, 30 May 2005 at 9:47 AM
Hi Stan,
It's ....... Lookin' good !!!
re: " ... I'm surprised I'm able to remember where I am with each one ... "
Just keep the dimensions correct so the different parts fit together and you will do just fine. ;=]
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
cherokee69 posted Mon, 30 May 2005 at 10:08 AM
Hey Doc,
I've made sure everthing is created is the same spots. I've done some tests to make use everthing (house, foundation, and front porch) will line up correctly when they are all put together and so far, everything works good.
I really didn't think this one was going to take as long as it has. The other 4 buildings didn't take this long but, for me, it's worth it.
One of my relatives (he married my 1st cousin) is a local artist around here and he does alot of pen and ink drawings and watercolors of old building and homes around here. His web site is "here". He hasn't seen these buildings yet but when I get it all done, he will.
Keep up the great work on your house tutorial. I know you'll be glad when that one is done.
Stan
Message edited on: 05/30/2005 10:17
geep posted Mon, 30 May 2005 at 10:24 AM
Hi Stan, I checked out his web site and it would appear that your 1st cousin-in-law is a very talented person. I am certain that he will appreciate seeing the product(s) of your labors when you show them to him. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
cherokee69 posted Tue, 31 May 2005 at 9:55 PM
Message edited on: 05/31/2005 21:59
geep posted Tue, 31 May 2005 at 11:29 PM
Hi Stan,
The "nerves" thingy ... done there, been that! ;=]
If you need to "leave it alone" for a while ..... that's ok ..... if it ain't fun, then don't do it.
I think you're doing a real 1st class job and I love the attic vent and eve brackets.
BTW - You're not cheating now and using Wings3D or something ....... are you?
cheers,
dr geep
P.S. Did you get my IM?
Message edited on: 05/31/2005 23:31
cheers,
dr geep ... :o]
edited 10/5/2019
cherokee69 posted Wed, 01 June 2005 at 10:07 AM
Doc, That's the reason it's taking so long, plus my work schedule takes alot of my time too and by the time I get home, sometimes I don't even feel like opening Poser to work on it. Anyway, since it's nice weather now, I hate being stuck inside. Wings3D? Nope, don't even understand how it use that or any other 3d modeling program. That's why I was so excited to be able to do this....in Poser. Got the IM and just replied. Stan
cherokee69 posted Wed, 01 June 2005 at 10:16 AM
cherokee69 posted Thu, 02 June 2005 at 9:39 AM
geep posted Thu, 02 June 2005 at 10:04 AM
WOW!!! It just keeps gettin' better 'n better! ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
cherokee69 posted Fri, 03 June 2005 at 10:24 PM
Message edited on: 06/03/2005 22:35
cherokee69 posted Fri, 03 June 2005 at 10:34 PM
geep posted Fri, 03 June 2005 at 10:40 PM
Yup, or try increasing the board's thickness. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
cherokee69 posted Fri, 03 June 2005 at 10:45 PM
Hey, you know Doc, I hadn't thought about doing that. Have to giv eit a try and see how that does.
geep posted Fri, 03 June 2005 at 10:56 PM
Ya just gots to think ouside the (magic) box, ya know. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
cherokee69 posted Mon, 06 June 2005 at 8:31 AM
Message edited on: 06/06/2005 08:35
geep posted Mon, 06 June 2005 at 8:48 AM
NaySayGuy wanted me to tell you this:
"Ah HA!!! ..... Dat's purdy cool!"
Excellent job Stan ... to bad you can't make models using Poser. (ha ha) ;=]
You are really becoming a "master" carpenter.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
cherokee69 posted Mon, 06 June 2005 at 9:58 AM
geep posted Mon, 06 June 2005 at 10:11 AM
Beautiful ... and I like the new arms better. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
