stonemason opened this issue on May 09, 2005 ยท 9 posts
stonemason posted Mon, 09 May 2005 at 4:03 AM
Attached Link: Generic Sci Fi Corridor
Generic Sci Fi Corridor Features Figures: G.S.F.C-.cr2(Comes in P4,Pro Pack & P5 versions) Presented as a figure with 10 body groups,allowing for movement of walls,ceiling etc.(All wheels,valves seen in renders are animatable) MAT Poses Default TEX.PZ2 Textures Off.PZ2 FloorLight.PZ2(flooring lights,Includes an 'Off' Pose) Floor01.PZ2(Texture variation) Floor02.PZ2(Texture variation) SideLights On.PZ2(Texture variation,,Includes an 'Off' Pose) Lights: 2 Bonus light sets evoking a moody atmospheric scene Medium res geometrie @ 49410 Facets 39 Material zones.stonemason posted Mon, 09 May 2005 at 4:04 AM
Attached Link: ACF_L20 'Aquatic Containment Facility'
Features Figure ACF_L20 .CR2(P4,PP,P5 Versions) (This environment is composed of 18 bodygroups,each wall section can be removed to speedup renders, Water level can be moved, Central column cabinet doors slide open, overhead cables can be removed, Central column can be removed) MAT Poses Default_PP.PZ2(default Pro-Pack texture pose) Default_P4.PZ2(default Poser 4 texture pose) Default_P5.PZ2(default Poser 5 texture pose) NoTex.PZ2(All textures off,) Railings Off.PZ2(Railings turned off) Railings On.PZ2(Railings turned on) FloorLights On.PZ2 FloorLights Off.PZ2 Lights Includes 3 Light sets (from a basic 8 spotlight setup to a more advanced 18 spotlight setup) Medium res geometrie @ 38525 Facets 72 Material zonesstonemason posted Mon, 09 May 2005 at 4:06 AM
Attached Link: Level 19
Features Figure:Level 19.CR2. (P4,PP & P5 versions included,) Body parts Main DoorLeft DoorRight BackWall Steps (The 'steps' body group has a 'switching geometrie' dial to switch the steps with an industrial styled elevator,simply turn the dial & the steps will be replaced) MAT Poses(P4,.PP,P5) to cover 58 material zones Default texture.Pz2 Textures off.Pz2 Lights:Includes the light set seen in promo renders Props:a concrete elevator shaft is included in the props folder. High res textures,transmaps & bump maps,P5 versions use Raytrace materials Medium res geometrie @ 39980 facetsstonemason posted Mon, 09 May 2005 at 4:08 AM
Attached Link: Containment Chamber
This environment has a unique three-room layout, with an entrance vestibule, a holding chamber and a pass-through area all connected by a central rotating chamber. This package also includes 11 camera settings, plus 2 light settings to get you started. The mesh has been properly optimized for Poser and modeled with the most economical number of polygons. Textures are of the highest quality allowing you to render top notch images Modelled by Moebius 87 textures by Stefan Morrellstonemason posted Mon, 09 May 2005 at 4:09 AM
Attached Link: Cyber-Seat
This is the definitive seating set only for the most descriminating of cyberjocks. Your Poser characters may be ready for the information age, but only the Cyber-Seat can guarantee that they are comfortable. Navigate the ether, surf the information frontiers, jack on to the virtual experience, or just plug-in to the web... this is how to do it. Ergonomically designed seating with the serious surfer in mind, supported by the very latest pseudo-engineering frame and chassis. Also includes a bonus "holo sphere" mesh, with custom display screens created by Moebius87. This set features moving parts and is an original Figure,Mec4D posted Mon, 09 May 2005 at 8:17 AM
Excellent products! and High level of Quality! My complements to both of you! Hugs! Cath
_________________________________________________________
"Surrender to what it is - Let go of what was - Have faith in what will be "
jarm posted Mon, 09 May 2005 at 11:38 AM
I have all of these, they are all great.
animajikgraphics posted Thu, 12 May 2005 at 1:02 AM
I have everything but GSFC and I agree, they're all fantastic. Have used them in several animations and pan to use them in an upcoming one. Look forward to new SF designs you come up with!
FatCatAlley.net | Now Playing "SpaceCat 5" Parts 1 and 2
Cylithera posted Thu, 12 May 2005 at 4:48 PM
SHEESH. These are.. gorgeous. ;) Fantastic job. You never fail to impress. ;)
