Forum: Bryce
Subject: Making phototextures seamless
dunedan opened this issue on May 10, 2005 ยท 5 posts
dunedan posted Tue, 10 May 2005 at 4:05 AM
Attached Link: http://img.photobucket.com/albums/v194/dunedan/7b832db9.jpg
I walked all over taking texture pics with my digicam, but my mind is all blank and I cant remember how to make them seamless. Isent there some easy way in photoshop or any other app?
What do you guys want for textures?
Here is a quicky with phototextures, showing how wrong it can look with non seamless textures :)
AgentSmith posted Tue, 10 May 2005 at 6:04 AM
In Photoshop; Use the filter; "Filter>Other>Offset". The numbers to plug in will be half the dimensions of your image. For instance, if it was 800x600, you would input 400 for horizontal and 300 for vertical. Also, don't for get to set it to "Wrap Around". This will reverse all your edges to the inside where you can clone stamp, or if you have it, "healing brush" the edges away. Run the offset filter again after you are done to check the edges again. AS
dunedan posted Tue, 10 May 2005 at 6:15 AM
Thanx AgentSmith, going to test that as soon as I get off work :)
dunedan posted Tue, 10 May 2005 at 2:08 PM
Man thanx again, that worked out really good. One sure can go wild with Clone stamp and make some cool textures... that I never have used this before doh! :D
lordstormdragon posted Wed, 11 May 2005 at 4:50 AM
Attached Link: http://flamingpear.com/download.html
Or, try Flaming Pear Tesselation. It's amazing and blends textures very well, although it depends on the kind of texture, too...
