TOXE opened this issue on May 10, 2005 ยท 6 posts
TOXE posted Tue, 10 May 2005 at 9:45 AM
fls13 posted Tue, 10 May 2005 at 10:09 AM
If you have Poser 4 PP or more recent, you can go back into the setup room and manipulate the hand directly until it is right, or in the pose room, select the bone that is a problem and then activate the joint editor and play with the xyz dials until those stray vertices bend the way they should. Of course, work on one side at a time and use the symmetry option under figures so you don't have to do it twice. :O)
PhilC posted Tue, 10 May 2005 at 10:11 AM
You are going to have to be very exact with the positioning of your spherical fall off zones. You may be better off if the hand were modeled with the fingers spread apart more.
xantor posted Tue, 10 May 2005 at 6:34 PM
Quite a few of the settings for the figures don`t work properly when you use bones from pre-made figures, usually the neck, head, eyes and fingers are the worst.
This is another thing that curious labs should fix with a newer version of poser.
Message edited on: 05/10/2005 18:35
TOXE posted Wed, 11 May 2005 at 1:58 AM
xantor posted Wed, 11 May 2005 at 6:34 AM
The figure looks like morph from the old tv programme.
