Forum: Bryce
Subject: DOF???
FranOnTheEdge opened this issue on May 11, 2005 ยท 40 posts
FranOnTheEdge posted Wed, 11 May 2005 at 5:00 AM
How do you do depth of field? I mean that I want to imitate the same effect that I get with my camera if I'm focussing on one object and the things behind it are less sharp. Is this the Depth of Field button just above on the right of the navigation ball with the big crossed arrows on it? Or is it something somewhere else?
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
lordstormdragon posted Wed, 11 May 2005 at 5:13 AM
The DOF options are in the Render options. Don't bother using it, though. The results are garbage compared to what you can do in Photoshop, and in 1/1000th the time it would take Bryce to render such a thing. If you have PS, or PSP, then render a distance mask in Bryce, and use that to drive the DOF blur. Much more efficient, smoother, and more realistic.
AgentSmith posted Wed, 11 May 2005 at 5:32 AM
Bryce can do DOF well, BUT...it is part of a "premium" render, and increases the render time a lot, and on top of that, it's very grainy/splotchy, so you have to really increase the RPP (rays per pixel), which REALLY increases rendering time, lol. But, still if ya want to experiment...select which item you want in your scene to be in focus (literally select the wireframe) - and click the following items in the Render Option window. The Lens radius of 0.10, that's the part you will increase to increase the strength of the DOF. There is no set number, each scene will be different. I usually start with 0.20, and go from there. AS
AgentSmith posted Wed, 11 May 2005 at 5:34 AM
That "Rays Per Pixel 64" will increase the number of rays shooting through your scene. Higher numbers will decrease DOF grain, but take it to the max number...and you better let your computer render while you're asleep. ;o) AS
AgentSmith posted Wed, 11 May 2005 at 5:38 AM
Yet, I have to 2nd what LSD said. I haven't renedered DOF inside of Bryce for probably years now. I can do DOF in Photoshop in seconds (not hours) with VERY smooth blurring, and the change of focus is completely change-able nearly instantly. AS
vasquez posted Wed, 11 May 2005 at 6:43 AM
Oh interesting.. this is a secret I've always wanted to know: how do you use a Bryce distance render as blur mask in photoshop, in order to obtain a DOF effect?
lordstormdragon posted Wed, 11 May 2005 at 6:53 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2068898
Vasquez, here's an excellent link to a discussion I had with Ser Smith a few months back... Enjoy! (Fran, check it out as well, of course!)
drawbridgep posted Wed, 11 May 2005 at 7:17 AM
Using the distance mask works pretty well, but it only seems to go from totally in focus at the camera and slowly blurs as you go deeper. With true (camera) DOF you can focus on an object deeper into the image. So things close to the lens are blurred, things in the midground are in focus and things in the background are blurred. Is it possible with the Object Mask method to do this?
Phillip Drawbridge
Website
Facebook
drawbridgep posted Wed, 11 May 2005 at 7:18 AM
For example, I took this picture and wanted to focus on the midground. You can do that with Bryce DOF, but not with object mask PS method?
Phillip Drawbridge
Website
Facebook
drawbridgep posted Wed, 11 May 2005 at 7:21 AM
Attached Link: DOF examples.
And finally, this link shows what effect increasing and decreasing values has in Bryce's DOF has.
Phillip Drawbridge
Website
Facebook
vasquez posted Wed, 11 May 2005 at 7:35 AM
WOW that's great I missed that thread! Thank you a LOT! LSD!!! and thank you also to AS for the other thread :)
lordstormdragon posted Wed, 11 May 2005 at 8:13 AM
Aye, you can isolate any object you want using Object Mask rendering, Drawbridge. This method is, in fact, the same method that Bryce uses when calculating it's internal DOF. You simply mix the Distance Mask and the Object mask as layers in Photoshop. You can do this by Multiplying or Screening your Object render against your Distance render. If you need more clarity from your Distance render, then you simply adjust the levels, or use Autocontrast. All of this in, like I said, 1/1000th the time that it takes Bryce. So, to answer your question, Yes. You can do it easier, faster, and with cleaner results in postwork. Try this technique on your above scene, you will find it much cleaner and more realistic. Or is your above scene actually a photo (grins!)??? And my last point : you cannot realistially animate Brycean DOF. You cannot even change the DOF over a timeline, or tween it, or keyframe it. You can do all of this with postwork animation, in After Effects, easily, and still have countless hours less downtime than if you sit around waiting for Bryce to clean up it's inherent graininess. Just because you CAN use an internal option doesn't mean you should... And in the time it takes you to render one such monstrosity, you could be on to your next scene and be rendering other things...
drawbridgep posted Wed, 11 May 2005 at 8:18 AM
Once my coffee takes full affect I think I may understand that. ;-) Actually it does make sense. I'll give it a go. And the above picture was a photo! :-) thanks
Phillip Drawbridge
Website
Facebook
Erlik posted Wed, 11 May 2005 at 9:40 AM
Since I read this thread, I been playing with just what lsd suggests. As you can see in the pic.
It's a combination of inverted distance mask and inverted object mask used as a filter mask in Photoshop. It's not perfect, most probably because the objects are small, so the distance mask doesn't have a big range as it would have if it were big. And the colours on the blurred objects are off. But, it's a start. :-)
BTW, for an even better of example of selective focus, take a look at this photo in my gallery. ;-)
-- erlik
Erlik posted Wed, 11 May 2005 at 9:54 AM
This one is better, cause the effect(s) were applied to the copy of the original colour pic and the blending mode set to Lighten. Although I used Smart Blur, Gaussian Blur and Digital Film Tools Defocus on it.
-- erlik
FranOnTheEdge posted Wed, 11 May 2005 at 10:08 AM
Can I pick out two things to remain in focus then? (using the quick method - which I didn't fully understand.) What is "render a distance mask"? And how do you do it? And is it better done in PhotoShop or PaintShop? Oh, and what's Object Mask? And how do you do that too?
Fran's Freestuff
Erlik posted Wed, 11 May 2005 at 10:23 AM
  1. Yes. Just select both. Ctrl+Shift+click on each. Appliable both to groups and individual models/primitives/meshes. 2) Sometimes called Z-buffer, IINW, it shows objects in varying shades of grey according to the distance from camera. IE from the viewport. Little triangle beside the Render buttons, and just select Distance Mask. 3) Whatever floats your ... pic. :-) All of us who talked apparently have Photoshop. Never tried Paintshop, but I believe it can be as easily done there. 4) Object Mask shows in white just the selected item(s) and rest of the pic is black. You can find it in the same place where you can find the Distance Mask.
-- erlik
aprilgem posted Wed, 11 May 2005 at 11:20 AM
I can't access the DAZ link right now (can't remember my password, and I'm at work), so I have no idea if this is already mentioned, but this is really the best way -- you can take the distance mask and adjust it in Photoshop so that the object you want focused is white and the rest is gray and black. Just use the Curves feature on the DOF alpha channel, click on the area where you want the focus, note where the circle shows up on the Curves line, put a marker where the circle was, and bring the top part of the line down -- making your marker the "highlight" of the Curves line. What this does is make your area of focus the whitest part of the alpha mask, and if you want, you can even further adjust it from there. Uh. This probably makes no sense, so I'll post some images...
aprilgem posted Wed, 11 May 2005 at 11:22 AM
This image shows how to adjust the curve...
aprilgem posted Wed, 11 May 2005 at 11:24 AM
Attached Link: http://art.aprilgem.com/bryce/bryce11.html
...and further adjustment. From here, you can invert the mask if you want so that your area of focus is black, so that when you select the mask, it's a much more precise selection of what you'd want blurred -- the object being the least blurred. Hope this makes sense to people. I've been using this technique forever. It's how I did the image linked.
aprilgem posted Wed, 11 May 2005 at 11:29 AM
Oh, and if you want just the lighter parts of the image to be blurred, you can select just the light parts of an image (Ctrl-Alt-Shift-~ on PC or Cmd-Option-Shift-~ on Mac), copy to a new layer (Ctrl/Cmd-J), blur, and set the layer to screen (or something). Of course, adjust this recipe to taste.
FranOnTheEdge posted Wed, 11 May 2005 at 11:59 AM
I'm afraid you're right - it doesn't make any sense to me. I don't recognise the program you're working in. It's probably PhotoShop in that case, as I've very rarely used it. So I wouldn't know how to even begin. Thanks for trying though. Sorry Erlik, same applies to what you said - it just went whooosh! Right over my head.
Fran's Freestuff
Erlik posted Wed, 11 May 2005 at 12:18 PM
Attached Link: http://www.daz3d.com/support/tutorial/index.php?id=891
1 is the triangle beside the render buttons. 2 & 3 are the Object and Distance mask settings. Click on the triangle, hold the left mouse button pressed, highlight one of them and release the button. At the link there's a simple Depth of Field tutorial for Poser at DAZ. The principles are completely the same. OTOH, you won't be able to do what I did. I will create a detailed tutorial on how to apply a selective DOF with Bryce and Photoshop.
-- erlik
FranOnTheEdge posted Wed, 11 May 2005 at 1:41 PM
Erlik, No, I meant the Postwork method, but thanks. I may have to take days after all... Trouble is my brother pays the electricity bill and if he found out, (and he will!) he'd hit the roof, so I wanted to do the postwork method.
Fran's Freestuff
tjohn posted Wed, 11 May 2005 at 2:19 PM
Been a long time since I've had calculus, so I don't understand most of the above, lol.
I have, however, used the DOF in Bryce quite a bit. Here are a few observations.
I use DOF with a rpp of 64, which gives good results IMHO. The results depend on how large your objects and scene are, and the camera settings (angle of the lens for instance).
My main gripe: the lens setting for DOF will only go down to .01. Does 5.5 have the ability to enter lower lens settings, like .001 for instance. This would allow greater control, most of what people don't like about Bryce's DOF, I think, is that even on the lowest setting, it is (depending on the effect desired) too strong. The only time I use DOF anyway is when I want the image to focus on a small part of the image. If the image is a landscape, there's no real reason for DOF to me. But if the image is an object or several objects on a tabletop surface, DOF can add a little realism, sort of like an adjustable focus on a real-world camera. Your taste may vary. :^)
Just my 2 cents.
Message edited on: 05/11/2005 14:24
FranOnTheEdge posted Wed, 11 May 2005 at 2:51 PM
This scene is already taking longer than I like - much longer and I'll forget what I was going to do... I have an object that I want to make the focus of a scene even though it will not be... centre stage so to speak. Actually I MAY want to have two objects sharp. Or I may not... (still thinking about that)
Fran's Freestuff
Erlik posted Wed, 11 May 2005 at 4:03 PM
I have some stuff to do and will be posting the tutorial in an hour or even less.
-- erlik
FranOnTheEdge posted Wed, 11 May 2005 at 5:13 PM
Oh goody! Thanks
Fran's Freestuff
lordstormdragon posted Wed, 11 May 2005 at 6:45 PM
AprilGem, it makes perfect sense to me! And was very well-illustrated... Thank you M'lady... A good thread, don't get too frustrated Fran, it will all make perfect sense to you soon enough. We're just inundating you with new Bryce stuff, but don't worry!
Incarnadine posted Wed, 11 May 2005 at 8:40 PM
I always had excellent results at 64 rpp with DOF in bryce 5. No grain issues, that I was aware of. Mind you, I never drove it beyond a slight effect - usually between .01 and a max of .05.
Pass no temptation lightly by, for one never knows when it may pass again!
lordstormdragon posted Wed, 11 May 2005 at 10:40 PM
Aye, but try the same scene in Photoshop with the above-mentioned methods, and compare them. You'll find the postwork options MUCH more realistic and accurate. Also, Bryce only allows ONE type of blurring for DOF. With Photoshop (or PSP, I'm using PS just for my example) you can use hundreds of different DOF filters. KPT Equalizer, Gaussian, Flaming Pear Melancholytron, or ANY filter you want. You can even use this technique for non-DOF related filtering, such as motion blur and whatnot... Not to mention lighting techniques. Couple that with the VAST time differences, and you're back to our original result : DOF in Bryce is a waste.
Kathye posted Thu, 12 May 2005 at 2:35 AM
Thank you, I found this and Erlik's very useful to work with. I'm already doing something a little like this to get DOF effect on my images but I'd say I'm still using it like a sledgehammer to crack a nut as I am only using the brightness and control to alter the mask. This might help me actually get a grip on curves enough to start learning that whole area. Never seen anyone talk about curves without having to write a whole book on it before :)
FranOnTheEdge posted Thu, 12 May 2005 at 4:56 AM
LSD, Oh I LIKE having lots of Bryce stuff thrown at me, (carefully wiping face) after all I did ask.
If it's for specific things I find I learn things better if I can actually try them out, rather than just hearing about part of a method in the middle of a conversation about something else, which can be intriguing but frustrating.
It's just that this particular image seems to be a really awkward one, everytime I think, "this is it, this render will be the last" I notice something really bad that I simply must fiddle with, so that instead of being finished days ago, I still have things to fix with each time taking another half day's fiddling - and when it's finally finished, I just bet it'll turn out not to have been worth the bother. It won't say what I wanted it to say, it just won't convey the impression I saw in my head in the beginning.
Tiresome really...
Message edited on: 05/12/2005 04:57
Fran's Freestuff
lordstormdragon posted Thu, 12 May 2005 at 5:06 AM
Aye, do you know what plop-rendering is, Fran? It can save you loads of time, if you plop-render just certain problem areas instead of re-running a full render.
FranOnTheEdge posted Thu, 12 May 2005 at 5:11 AM
Yes, I use it all the time, for small details. But the problems I've been having lately are when I've used terrains to create mist, I find that the edges of the terrains show odd downward streaks, so I'm quite glad to think (hopefully not mistakenly) that the PhotoShop DOF technique will give me the right focus on my main object without trying for days to make good mists - only to end up with funny streaks when I though I'd finally cracked it! (sigh)
Fran's Freestuff
lordstormdragon posted Thu, 12 May 2005 at 5:47 AM
Aye, perhaps you'll give us a screenshot? We might be able to help you better that way.
Kathye posted Thu, 12 May 2005 at 6:51 AM
Fran said ""this is it, this render will be the last" I notice something really bad that I simply must fiddle with, so that instead of being finished days ago,"- Boy do I know that feeling with my current image! I did an overnight render thinking 'ok, this is it, three weeks working on it and this should be the one I finally run with.' But no, I can still see things to tweak. I'm beginning to wonder if there are always going to be things about some image that look like they need improving. Or maybe I've just hit a perfectionist stage.
lordstormdragon posted Thu, 12 May 2005 at 6:53 AM
"Art is never finished, merely forgotten..."
FranOnTheEdge posted Thu, 12 May 2005 at 12:17 PM
Okay, here are the Mist Streaks:^^^^^^^^
Fran's Freestuff
FranOnTheEdge posted Thu, 12 May 2005 at 3:53 PM
Um, forget the mist streaks - fixed them myself. Had a snooze in front of the TV and when I woke up I thought to myself - "I'll just try that out". I did, & it worked!
Fran's Freestuff
