Subject: Help with infinity cove?
stefanino opened this issue on May 11, 2005 ยท 3 posts
stefanino posted Wed, 11 May 2005 at 12:10 PM
Hi, i have biught the infinity cove from Dna,and also the tropical waerscape, but i am not able to use it! :( I open the prop and than apply a texture from the pose library, and nthing happened.... May i have to have something else to make it run? Thanks and many greetings! Stefanino
jwiest posted Wed, 11 May 2005 at 1:16 PM
I don't actually have the product you're speaking of (though I'm thinking of getting it). But I do know with other Poser objects, sometimes you won't see the actual texture until you render the scene. It could also have to do with the settings of your view. Also, double check that you have that object selected as the active one when you try to apply the material and not another one like a person or other prop.
John
stefanino posted Wed, 11 May 2005 at 2:13 PM
Hi jwiest,was only to render the scene and aply the texture to the appropriate object, bakground and ground! Stupid me! :)) Thanks very much from a newbee, that has a lot to learn! Many greetins Stefanino
