Jalad opened this issue on May 11, 2005 ยท 8 posts
Jalad posted Wed, 11 May 2005 at 9:08 PM
just trying to figure out how to control which body parts a magnet is applied to. i have loaded a magnet designed by someone else that applies to the abdomen, but it looks funny to have the effect end abruptly at the line where the hip starts, so i want the magnet effect to apply to both the abdomen and hip for a continuous effect. i thought i remembered seeing a tutorial on magnets here that explained this, but now i don't see one. i'm sure this is a simple thing. thanks for the help!
madmaxh posted Wed, 11 May 2005 at 9:15 PM
If you select the magnet, you will see a button in the properties box that allows other body parts to be added within the magnet's effect radius. ;D
Jalad posted Wed, 11 May 2005 at 9:27 PM
that was fast. thanks! and it sounds like it couldn't be easier. now off to give it a try! j
Photopium posted Wed, 11 May 2005 at 9:57 PM
I believe that Wyrmmaster gets the credit for discovering the following: It works better if you create a second magnet for the hip (In this case) but position everything exactly where the abdomen one is (base, zone and same magnet settings). The reason is joints. If you bend the abdomen too far, the zone will slip off of the hip and create a horrible distortion, but under this set-up the hip mag stays with the hip and keeps it all flowing beautifully. All functional magnet sets are built on this premise. -WTB
madmaxh posted Wed, 11 May 2005 at 10:20 PM
Point well taken, William. You're absolutely right! :D
Jalad posted Wed, 11 May 2005 at 11:03 PM
aha! that sounds even better. once again off to try out my new knowledge. thanks!
Photopium posted Thu, 12 May 2005 at 12:52 AM
Magnets for all, that's what I say! They are a delight once you get 'em. Shameless Plug while I'm here: Universal Magic Mags in the marketplace. Mags made easy for nearly any poser figure. -WTB
Xena posted Fri, 13 May 2005 at 1:42 AM
WTB is right about using double mags. It's a terrific way to beat the weirdness on bending. But you don't need to do it if you're only making a morph and then removing the magnets. Just do as madmax said :) Magnets for all ..... damned fine idea WTB :D I don't know how people live without them ;)
