Avalonne opened this issue on May 12, 2005 ยท 8 posts
Avalonne posted Thu, 12 May 2005 at 5:59 PM
Can anyone tell me how the heck to make a reflection in Poser 6? I think I have tried every method I can think of, and nothing works :-( I even tried the Poser 5 reflection tutorial by mobius, and that didn't work, either....any help would be greatly appreciated and many thanks in advance :-)
Ajax posted Thu, 12 May 2005 at 7:01 PM
If you download my shader pack from free stuff it includes some reflective materials. Key things you need to do to make them work are: -Make sure raytracing is turned on in your render settings. -Make sure your reflective object has things around it that it can reflect (putting it inside a fully enclosed room is a good way to go).
View Ajax's Gallery - View
Ajax's Freestuff - View
Ajax's Store -
Send Ajax a message
Shardz posted Thu, 12 May 2005 at 11:47 PM
Here is a decent tutorial at Daz regarding basic raytraced reflections on the Ground plane prop (I used that technique in my Sensuous Black image, and it applies to Poser 5, as well).
http://www.daz3d.com/support/tutorial/index.php?id=939
Also, for the final render, turn on raytracing in the render options. You won't get reflections unless it's raytraced! I hope this helps!
Tiny Glasshoppa, Big Shadow!
-Shardz-
Message edited on: 05/12/2005 23:55
Avalonne posted Fri, 13 May 2005 at 5:30 PM
Thanks to both of you...I tried what you said, and I am still getting no reflection :-( I have NO idea what I am doing wrong....
nruddock posted Fri, 13 May 2005 at 5:55 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2193249
See linked thread.If this isn't your problem, please post a render and screenshots of the material room for the Ground Plane, and your Render settings.
Ajax posted Fri, 13 May 2005 at 5:55 PM
Can you post screenshots of your material room and your render settings?
Ajax's Store -
Send Ajax a message
Xena posted Sat, 14 May 2005 at 2:09 PM
bookmark - then runs off to get Ajax's stuff :)
Avalonne posted Sun, 15 May 2005 at 5:49 PM
I went and read your crosspost, did what you said and Voila....I got a reflection...thank you soooooooooooooooooo much!!!!! http://www.renderosity.com/viewed.ez?galleryid=957328&Start=1&Artist=Avalonne&ByArtist=Yes
